SVS 25-31PC+ 20 Hz tune (dB12.2) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss SVS 25-31PC+ 20 Hz tune (dB12.2) in the Manufactured Speakers and Subwoofers forum; SVS 25-31PC+ 20 Hz tune (dB12.2) Manufacturer: SVSound Model: 25-31PC+ Provided by: Arttu78 Manufacturer link: SVSound - Cylinder Subwoofers Price: $775 Manufacturer specs: Proprietary TC-Sound 12" ...
Old 07-16-06, 02:52 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: 25-31PC+
Price: $775
Manufacturer specs:
Proprietary TC-Sound 12" high output woofer
Computer Assisted Design (CAD) enclosure
Flush-mount, internal 525 watt BASH amp
Exclusive down-firing cylinder design
Compliant floor mounts, low center of gravity
"Tri-Power" 3" High-flow ports with port block
User variable tuning: 25 Hz (stock), 20 and 16 Hz
Resonance free, protective top grill
High-strength polymer wrapped enclosure
CNC'd black laminated, 1.5" birch end-caps
Architectural-grade black fabric exterior
Dimensions: 32" tall, 16" diameter
Weight: 23 kg
+/- 3 dB 25-100 Hz (25 Hz config) quasi-anechoic response (in-room extension will be 3-4 Hz deeper)
Configuration as tested:
Phase: 0 degrees
Tuning frequency: 20 Hz (one port plug)
Subsonic filter: 20 Hz
Orientation: Standard down-firing
This unit has a dB12.2 woofer
Old 07-17-06, 10:23 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
+/- 3 dB points: 19 Hz - 120 Hz
Old 07-17-06, 10:24 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-17-06, 02:18 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
The shape of the frequency response becomes a bit better when plugging one of the ports. One gains around 5 Hz in extension due to this operation. Naturally the mid bass output takes around 2 dB hit, and the deep bass output gains by the same amount. Output compression grows larger around the tuning frequency due to lowered port area. The crossover works as promised and has a steep enough slope for 2-channel use. THD stays really low down to 20-23 Hz. Group delay stays below the 1 cycle limit. Spectral decay shows some added ringing around the tuning frequency compared to the 25 Hz tune. Spectral contamination test shows higher than average maximum output with low overall distortion.
+ Good extension
+ High mid bass output
+ Low overall distortion at all output levels
+ Overall price/performance ratio
+/- Look and weight of the cylinder
- Shape of the frequency response
- Somewhat high deep bass group delay and some ringing around the tuning frequency
Old 02-13-07, 12:46 AM   #5 (Link)
Alias: Tucker76
Loc: St Louis Mo (City)
User: #5722
Since: Jan 2007
stlfdemt is offline
Re: SVS 25-31PC+ 20 Hz (dB12.2)
I wish my wife would let me get a cylinder sub
Old 02-13-07, 10:50 AM   #6 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Ilkka, great work! These boogers are really amazing when you factor in price. I had a 16-46PCi and loved it. Now I have the PB12-Plus/2 with the new drivers-Love it! Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
SVS PB12-Plus/2 20 Hz tune (dB12.1) Ilkka Subwoofer Tests 6 05-16-08 12:23 PM
FS: SVS db12.2 Drivers Josuah Classifieds - Speakers and Subwoofers 6 10-29-07 10:45 PM
SVS PB12-Plus/2 20 Hz tune (Plus 12.3) Ilkka Subwoofer Tests 21 03-24-07 06:38 PM
SVS 25-31PC+ 25 Hz tune (dB12.2) Ilkka Subwoofer Tests 3 07-17-06 02:19 PM
SVS PB12-Plus/2 25 Hz tune (dB12.1) Ilkka Subwoofer Tests 3 07-17-06 02:17 PM
Mach 5 Audio
