| Subwoofer Tests SVS PB10-ISD (2nd unit)Discuss SVS PB10-ISD (2nd unit) in the Manufactured Speakers and Subwoofers forum; SVS PB10-ISD (2nd unit) Manufacturer: SVSound
Model: PB10-ISD
Provided by: Ilkka
Manufacturer link: SVSound - Box Subwoofers (has been replaced by identically performing PB10-NSD ... |
| | #1 (Link) | |||
| SVS PB10-ISD (2nd unit) Manufacturer: SVSound Model: PB10-ISD Provided by: Ilkka Manufacturer link: SVSound - Box Subwoofers (has been replaced by identically performing PB10-NSD model) Price: $429 Manufacturer specs: • Proprietary SVS-designed long-throw 10" woofer • 300 watt BASH digital switching amp • Computer aided cabinet design with 1" front baffle • Front-firing design with flush fit woofer and vent • Patented 3" wide-flare port fittings • Six removable, compliant floor isolation points • Four finish choices to match any décor • Color-keyed fabric grill with chromed mounting pins • Extra heavy-duty, removable 8 foot power cord • Contemporary, "seamless" cabinet styling • +/- 3dB from 20-100 Hz anechoic, in room extension will be 2-5 Hz deeper • Size: 15 ½" wide x 19" high x 21 ½" deep • Weight: 60 pounds • 220~240V 50/60Hz configuration available Configuration as tested: Phase: 0 degrees Orientation: Woofer facing the mic This is not the same unit which was tested last fall ![]() ![]() | |||
| | #4 (Link) | |||
| The cheapest and smallest one of the SVS offerings (at the time). When considering that, it's kind of surprising that it has the flattest frequency response of the SVS subwoofers I have tested. A small hump at 60 Hz and a slope above it doesn't look that bad. The shape of the frequency response suits better for larger rooms having not much deep bass room gain. Otherwise the sound may become too bottom heavy. The PB10 doesn't have a built-in crossover, so a traditional 2-channel use won't work without an external crossover. The maximum output, both mid and deep bass, is relatively high for a 10" subwoofer. It breaks the 100 dB barrier at all frequencies above 25 Hz. A single 3" port and a high output won't come without expenses - there is quite audible port noise at high output levels. THD profile is rather strange with much higher than typical THD above 40-50 Hz; luckily it’s mainly low order distortion. Group delay stays low down to 30 Hz, but goes quickly well above the 1 cycle curve below. Spectral decay shows a lot ringing around the tuning frequency. Spectral contamination test shows average maximum output capability with higher than average overall distortion. The black vinyl finish looks somewhat cheap. The overall build quality is above average. + Good extension + Good frequency response for larger rooms + Relative high overall maximum output capability - High upper bass distortion - High deep bass group delay - Slow deep bass decay rate - No crossover | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Face-Off - SVS PB10-ISD Takes On A Few Contenders | Wayne A. Pflughaupt | Home Audio Subwoofers | 24 | 06-04-08 12:25 PM |
| SVS PB10-ISD (sealed) | Ilkka | Subwoofer Tests | 5 | 08-19-07 08:34 AM |
| SVS PB10-ISD (1st unit) | Ilkka | Subwoofer Tests | 5 | 08-19-07 08:32 AM |
| Face-Off - SVS PB10-ISD Takes on a Few Contenders | Wayne A. Pflughaupt | SVSound | 4 | 04-29-07 09:07 PM |
| PB10-ISD on Clearance | JCD | SVSound | 0 | 06-01-06 02:06 PM |
