Go Back   Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Register
Subwoofer Tests
SVS PB12-Plus/2 25 Hz tune (dB12.1)
Discuss SVS PB12-Plus/2 25 Hz tune (dB12.1) in the Manufactured Speakers and Subwoofers forum; SVS PB12-Plus/2 25 Hz tune (dB12.1) Manufacturer: SVSound Model: PB12-Plus/2 Provided by: JaniH Manufacturer link: SVSound - Box Subwoofers Price: $1199 (black), $1399 (wood veneer) (dB12.1 ...
Old 07-16-06, 02:57 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: PB12-Plus/2
Provided by: JaniH
Price: $1199 (black), $1399 (wood veneer) (dB12.1 woofers not available anymore)
Manufacturer specs:
• Proprietary TC-Sound 12" high output woofers
• SVS designed, full-featured 900 watt BASH (R) digital switching amp
• Premium finishes ship with on board Parametric EQ (PEQ)
• Built-in, flush-mount amp configuration
• Down-firing woofers with distinctive SVS integrated base-plate
• Compliant floor mounts, ultra low center of gravity
• Three tuned, patented 4" high-flow flared porting (in and out)
• Assembled and tested by SVS in its Ohio factory
• Extra heavy-duty detachable 8 foot power cord
• 6 wood-finishes
• Selectable 16Hz, 20Hz or 25Hz extension with included port plugs
• Size: 48 cm wide, 67 cm tall and 71 cm deep.
• Weight: 64 kg
• Frequency Response: +/- 3dB to 20hz anechoic
• 3 years warranty
Configuration as tested:
Phase: 0 degrees
Tuning frequency: 25 Hz (no port plugs)
Subsonic filter: 25 Hz
Orientation: Standard down-firing, ports facing left
This unit uses dB12.1 woofers
Old 07-17-06, 10:26 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
+/- 3 dB points: 22 Hz - 85 Hz
Old 07-17-06, 10:26 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-17-06, 02:17 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
The older version of the second-largest SVS showed a typical frequency response for an SVS subwoofer - excessive deep bass output compared to the upper bass output. That isn't a good thing because it will result in an excessive amount of deep bass output, which will make the sound too bottom heavy unless external EQ is used. The built-in crossover works as promised and the slope is steep enough for 2-channel use. The subwoofer shows a respectable mid/upper bass output, though not extremely good when considering it has two 12" woofers in a rather large vented enclosure. It just breaks the 110 dB barrier in 30-50 Hz range. Deep bass output is naturally a little bit compromised due to the 25 Hz tuning frequency, though still a very good performance in this test group. THD stays quite low all the way close to the tuning frequency, though rising quite a lot in the upper bass range at the highest output levels; luckily it’s mainly 2nd order. Group delay grown rather large below ~35 Hz. Spectral decay shows quite a lot of ringing around the tuning frequency. Spectral contamination test shows high output capability with lower than average overall distortion. The overall build quality is good, and the black vinyl finish is durable, but looks a little bit cheap.
+ Pretty good extension
+ High overall maximum output capability
+ Low overall distortion
+ Overall price/performance ratio
- Shape of the frequency response
- Somewhat high deep bass distortion
- High upper bass distortion at high output levels
- High deep bass group delay and ringing around the tuning frequency
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
SVS PB12-Plus/2 20 Hz tune (dB12.1) Ilkka Subwoofer Tests 6 05-16-08 12:23 PM
FS: SVS db12.2 Drivers Josuah Classifieds - Speakers and Subwoofers 6 10-29-07 10:45 PM
SVS PB12-Plus/2 20 Hz tune (Plus 12.3) Ilkka Subwoofer Tests 21 03-24-07 06:38 PM
SVS 25-31PC+ 20 Hz tune (dB12.2) Ilkka Subwoofer Tests 5 02-13-07 10:50 AM
SVS 25-31PC+ 25 Hz tune (dB12.2) Ilkka Subwoofer Tests 3 07-17-06 02:19 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
