Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
pb-13 in big room!
Discuss pb-13 in big room! in the Manufactured Speakers and Subwoofers forum; pb-13 in big room! Anybody running just one of the PB13 in a room similar to 20x22 with 16' vaulted ceilings and opening up ...
Views: 638 - Replies: 4
Old 03-18-08, 02:19 PM   #1
Alias: jose
Loc: Marion, Ky
User: #16625
Since: Feb 2008
  bwinders is offline
pb-13 in big room!
Anybody running just one of the PB13 in a room similar to 20x22 with 16' vaulted ceilings and opening up the the rest of the house? I have it in the rear corner behind the couch for best results. I am afraid the room is so big that the crumbling bass that people talk of with only be accomplished through 2 or 3 of these things. Don't get me wrong the bass is nice but I might be suffering from the syndrome some have "what if..."
Old 03-18-08, 02:32 PM   #2
Alias: Ron
Loc: San Jose, CA
User: #12483
Since: Oct 2007
  Ron Temple is offline
Re: pb-13 in big room!
bwinders wrote: View Post
2 would definitely do it...have you talked to Ed about maximizing your current situation?
Old 03-21-08, 04:38 PM   #3
Alias: jvanhambelgium
Loc: Antwerp
User: #14046
Since: Dec 2007
  jvanhambelgium is offline
My room is also >7000 cubic feet and it is powered with 1 PB13-Ultra.
What do you define as "nice" ?
Playing scenes like WOTW, Nemo (Darla) or U571 is not only "nice", but rather "impressive" in my room playing at around -15 or -10 ... and I'm sure there is more in the beast when looking at driver-excursion...
I have it in a living room, not a dedicated HT and the room is not acoustically treated in any way.
It can still scare me and those watching movies here...and that is what counts ;-)
Old 03-21-08, 06:03 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
The only reason some people have more than one is simply to give higher db levels. and can actually cause issues will nulls and even cancel each other out if not set up properly. One PB13 should have no issues with filling a room of your size with lows in around 15hz. at around 100db
I currently have a 10" long excursion box sub with a unique design in that it is both a sealed bandpass and ported enclosure that has a frequency response of 20-100hz at 104db and it fills my room easily that is 15x30' (soon to have a PB13 Ultra)
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 03-21-08, 06:41 PM   #5
Alias: mojomike
Loc: South Florida
User: #6557
  mojomike is offline
It all gets down to your particular needs. In my opinion even though the PB13 is capable of big output, one PB13 in that room will not get you "crumbling" bass. It will give you very sufficient bass under most circumstances. If you expect "reference level" bass (115db at your listening position) two PB13's would be needed.
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
