| SVSound SVS SBS/SCS-01 Difference in sound?Discuss SVS SBS/SCS-01 Difference in sound? in the Manufactured Speakers and Subwoofers forum; SVS SBS/SCS-01 Difference in sound? What does a comparison look like between having the sbs-scs-sbs fronts......
and a.... scs-scs-scs fronts......???
trying to decide between sbs ... |
| | #1 (Link) | |||
| SVS SBS/SCS-01 Difference in sound? What does a comparison look like between having the sbs-scs-sbs fronts...... and a.... scs-scs-scs fronts......??? trying to decide between sbs and scs for my right and left fronts. your thoughts?? thanks | |||
| | #3 (Link) | |||
| Re: SVS SBS/SCS-01 Appearance whoops.... comparison on sound. what does it 'look like' comparing 3 scs's across the front....vs. sbs, scs (center) and sbs...... what is the audible difference, sound quality comparison. thanks matt | |||
| | #7 (Link) | |||
| Re: SVS SBS/SCS-01 Difference in sound? is there a minimum distance between the left and right. the problem is the corner placement....it's the only possible setup in my situation. maybe 60inches apart (at best) is the max i could go between them. on will be on a stand...one will sit on the hearth of the mantle....both will be approx. ear height. also...is there a way to know how far to 'toe in or out' the left and right to cover the field. i'll be purchasing a yamaha 663 soon. will the auto setup determine this.....or just adjust output based on distance. thanks matt | |||
| | #8 (Link) | |||
| Re: SVS SBS/SCS-01 Difference in sound? I have gone in stages from adding the SCS all across the front and now all the way around. The sound difference is very noticable! Upgrade as your budget allows but I would def. recommend it! | |||
| | #9 (Link) | |||
| Re: SVS SBS/SCS-01 Difference in sound? what do you do when you upgrade like that. what did you with your old sbs-01's?? i noticed in another thread that SVS doesn't take ''trade-in's'' (for lack of a better word) when people upgrade. thanks. | |||
| | #10 (Link) | |||
| Re: SVS SBS/SCS-01 Difference in sound? Sorry, I haven't been on here since 4/24 apparently. When I originally started buying I got the SCS and SBS fronts only. I just kept my back ones I was already using. Then bought 2 more SCS for the front and moved the SBS to the back. When I got SCS all around I just boxed the SBS to use when I upgrade my receiver to 7.1. I don't see any reason to have SCS for the 6 & 7 speakers. I upgraded from *cough*Bose*cough* and it's been wonderful as you can imagine. | |||
| | #11 (Link) | ||||
| Re: SVS SBS/SCS-01 Difference in sound? Quote:
If you haven't done it already, if you email SVS, techsupport@svsound.com , with your questions just like this they'll be super helpful. | ||||
| | #12 (Link) | |||
| Re: SVS SBS/SCS-01 Difference in sound? i noticed in another thread that people see 'matching' bookshelves as very important for sound quality. ie. in a 5.1 system....all 5 should match. is there any truth to this. will i notice a difference if i use LCR scs-01's and surround sbs-01's?? any further info is appreciated. thanks matt ps. still struggling with the sub decision. pb-12 nsd vs. 20-39 pci vs. 20-39 pc-plus vs. pb12-plus/2 vs. pb12-plus.....and on and on. | |||
| | #13 (Link) | |||
| Re: SVS SBS/SCS-01 Difference in sound? will i notice a difference if i use LCR scs-01's and surround sbs-01's?? In movie playback, it's noticeable but not as much and if that's most of your listening then stick with that config. But if you play hi-rez surround music, then it is very noticeable. Basically, yes, you will notice a difference. You just have to decide how important it is to you and your listening habits. Personally I'd highly recommend it. Email SVS on the sub decision. You can give them your room dimensions and other info. and they can really help you a lot. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| SVS sbs-01 speaker stand question | vv132 | SVSound | 4 | 06-10-08 10:49 AM |
| SVS SBS/SCS-01 Home Theater Ensemble: Good Things Come in Small Packages | Wayne A. Pflughaupt | Home Audio Speakers | 5 | 05-30-08 02:54 PM |
| SVS SBS-01 & PB12-NSD review - Audiophile.no (English version) | L-Sound - Jan | SVSound | 1 | 05-28-07 02:53 PM |
| SVS SBS/SCS-01 Home Theater Ensemble: Good Things Come in Small Packages | Wayne A. Pflughaupt | SVSound | 1 | 04-29-07 03:53 PM |
| SVS 25-31 PC-Plus Subwoofer with SVS SBS-01 5.0 package = Enormous Bang For the Buck! | Kipp Jones | SVSound | 1 | 02-11-07 08:04 AM |
