| SVSound SB12-Plus "Rosenut" first shots...Discuss SB12-Plus "Rosenut" first shots... in the Manufactured Speakers and Subwoofers forum; SB12-Plus "Rosenut" first shots... Ron sent these out to a few folks and I thought I would share them... WARNING: Possible widescreen on low ... |
| | #1 (Link) | |||
| | SB12-Plus "Rosenut" first shots... Ron sent these out to a few folks and I thought I would share them... WARNING: Possible widescreen on low resolution settings... for best viewing set your resolution to 1280 X 1024 ... .... ![]() ![]() ![]() ![]() ![]() Features:
| | #3 (Link) | ||||
| Re: SB12-Plus "Rosenut" first shots... Quote:
![]() A few questions to Tom: Is the driver exactly the same Plus 12.3 as you use with vented subs or has it been tweaked to match better into a sealed box? Are you using a HP filter or is the final roll-off 12 dB/oct? Any FR graphs yet? | ||||
| | #6 (Link) | |||
| Re: SB12-Plus "Rosenut" first shots... "Rosenut" - is that a hybrid of Rosewood and Walnut? ![]() | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | |||
| | #7 (Link) | |||
| Re: SB12-Plus "Rosenut" first shots... Malice, Something like that. It's a special "wave grain" cut of walnut (I think it's walnut, I have to verify that) that's finished like cherry. The result is much more subdued and less "red" than our outgoing cherry, but a lot less garish than the heavy grain of the rosewood. We find it to be the perfect blend of the two, and really nicer than either. Every single person who's seen "Rosenut" says it's "the bomb". Which as a true American idiom, is a good thing. The examples I've seen so far have even higher quality than predecessor wood veneer cabinets (which is saying quite a lot). Ron SVS | |||
| | #9 (Link) | |||
| Re: SB12-Plus "Rosenut" first shots... Dundas, No Cherry. This finish is replacing it. We still have Cherry in the big subs ( PB12-Plus etc) however. Much of the feedback we get was simply that cherry was "too red" and also that rosewood was too much an "acquired taste". So we merged the best of both into this new finish. Ron SVS | |||
| | #12 (Link) | |||
| Re: SB12-Plus "Rosenut" first shots... Beautiful!! I've seen alot of different woods and finishes, (over 30 years of carpentry and cabinet making here), and I must say, that is one FINE looking veneer!! Hope it sounds as good as it looks! I'm sure it will!! Congrats!..... -Colin G. | |||
| | #13 (Link) | ||||
| Re: SB12-Plus "Rosenut" first shots... could anybody confirm this is 12.3 driver? Quote:
| | #14 (Link) | |||
| Re: SB12-Plus "Rosenut" first shots... Colin, I've been working with/in wood for many years too (before I joined the Army I actually worked in a lumber yard believe it or not) and our latest generation of cabinets which we import are indeed shockingly good. They are still hand finished realwood, which means each is unique and can never be truly flawless, but you are not going to come closer even if you double or triple the price point from what I've seen of the industry. And this is indeed the same Plus 12.3 woofer in our larger vented subs. It was actually developed to play both roles right from the start. It would perhaps have been easier to come up with specific designs for both applications but we like a challenge (and our material manager of course asks the staff to use common parts where it's possible). When the project was started, not all of us thought it WAS possible, but when folks see the frequency response and performance of the SB12-Plus they will know no compromises were accepted. The woofer had to be a true "switch hitter" that could exceed the performance of our "old" Plus driver in the big, traditional vented alignments... and still be as good in a small sealed application as anything designed only for that purpose. I spent a good bit of this last weekend with others hammering a pre-production SB12-Plus without mercy. Having been among those individuals that have panned small subs in the past, I can tell you that in a small to mid-sized room this newest SVS product will make "small" less of a compromise than I ever imagined. You will still be better off with a big vented sub on a sheer price/performance basis of course (size matters, still) but if your significant other wants a small sub, or your room isn't big enough to play rugby, then I can honestly say that finally there's at least one small sub that's affordable, great looking, and performs so well that you start to believe the proclamation that size is NOT "all that". It's a head turner in virtually every regard: price, size, build quality and performance all at one time. I know no one following us for a while now is surprised (even if we can say flat out that the product exceeds our goals in virtually all those aspects). Ron SVS | |||
| | #15 (Link) | ||||
I think I should of clarified my first post a little better to everyone. When I mention your subs veneer, I should of also included that I believed it to be "real wood", as you just confirmed with your reply, and each sub is unique in appearance, which is true with real wood I'd also like to thank you and Tom for the NSD driver offer that you had for existing customers. I just picked mine up Friday at your Ohio factory, and I feel it is a very nice upgrade over the ISD. -Colin G. | ||||
| | #16 (Link) | |||
| Re: SB12-Plus "Rosenut" first shots... anyone can tell me sealed vs vented? why SVS change to sealed sub? is it any better than vented? proud to be first SVS user in TW! and so proud to be first TW user with 2 SVSes! now TW first Onkyo 905 user! ![]() threads http://www.hometheatershack.com/foru...s-user-tw.html http://www.hometheatershack.com/foru...html#post32842 http://www.hometheatershack.com/foru...html#post47160 http://photo.pchome.com.tw/lienly | |||
