| SVSound SVS PB13 Ultra ReviewDiscuss SVS PB13 Ultra Review in the Manufactured Speakers and Subwoofers forum; SVS PB13 Ultra Review Thanks to The Home Theater Shack and SVSound I received my PB13 Ultra yesterday afternoon.
I will be posting a ... |
Views: 6825 - Replies: 38
| SVS PB13 Ultra Review Thanks to The Home Theater Shack and SVSound I received my PB13 Ultra yesterday afternoon. I will be posting a review and pictures about it in this thread SEE BELOW. Day one, First Impressions: Let me say that this is the most amazing sub I have ever seen and heard for home theater! The build quality and looks is no less than an A+. The size alone is just plain amazing. During my initial testing of it I had the very structure of my house vibrating because of the db levels this PB13 puts out. ![]() ![]() More info to come. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #2 | ||||
| Re: SVS PB13 Ultra Review Thaks for the update, Tony. Looking forward to your impressions as the days go by. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #4 | ||||
| Re: SVS PB13 Ultra Review Good news Tony! According to Ilkka's tests this is an excellent performer! ![]() Congrats! ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #5 | ||||
| Re: SVS PB13 Ultra Review SVS are really doing well at the moment and this Sub only proves this... Great performance, good price and compact package! Cant wait to see some more detailed information plus the all important subjective review as well as pictures | ||||
| | #7 | ||||
| Re: SVS PB13 Ultra Review Ok, here we go, The delivery of the PD13 Ultra was quick (form Ontario to Alberta less than 3 days ground) The box is huge and weighs 160lbs ![]() Getting this beast into my basement was not as difficult as I thought it would be as once I had it in my back entrance using a dolly I just used gravity and let it slide slowly down the stairs. The sub is packed really well with rigid 3" thick foam all the way around. ![]() Once out of the box (had to turn the box on its side to do so) I took off the plastic wrap and hulled out my old A/D/S MS3u sub and placed it beside the Ultra, You can really see the size difference in this photo. ![]() The fit and finish of the PB13 Ultra is really something to talk about. It looks amazing just sitting there and will most defiantly be a conversation piece in any room. The back panel BASH amp is also well put together with every option you can imagine. Including: Phase control Gain adjustment Subsonic filter (used when closing off one or more of the front ports to get a lower frequency response) with settings of 20hz, 15hz, 10hz, and sealed. A Parametric EQ Crossover setting with RCA High pass filter switch Room compensation size (small medium and large) And also comes with balanced XLR and unbalanced RCA inputs ![]() Once the sub was in place it really becomes a part of the systems over all look and from the listening position does not look out of place. ![]() Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage Last edited by tonyvdb; 06-24-09 at 02:16 PM.. | ||||
| | #8 | ||||
| Re: SVS PB13 Ultra Review I decided to set the PB13 Ultra at the 15hz setting with one port plugged. I want the lower frequency's to be strong rather than have it with better output at higher SPL's although still not by any means "low" dbs as it still can reach well over 100dbs with that setting. I sent a test tone of 20hz to it from a test CD that I have and I literally had the entire house vibrating and that was only at a reasonable 90dbs. I then played the opening section of video from the DVE DVD (I forgot to turn the volume down on the receiver and absolutely scared the pants off of me) The DB levels of my entire system was over 100 as I still had the SA-3051 turned on! The sub really brings the entire system together with a fullness that I have not heard before. The lows are astonishing I can only imagine once this sub is tuned properly and has had some time to break in that it will really smooth out (I am a firm believer that a speaker needs time to break in before it preforms to its fullest). Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #9 | ||||
| Re: SVS PB13 Ultra Review Hi Tony, I also just got a SVS PC 13 ultra as I liked the look of the upright cylinder and it somewhat disappears in my room behind the TV. I will try the 15 hertz setting with one port plugged. I am really enjoying the ambient LFE base effects but I probably have turned up the sub an extra 10 db. On the base frequency sweep test it rattled the pictures on my wall! How do you recomend setting the phase? I haven't done this yet. What are the speaker settings in your receiver? Audyssey has set mine to full. What do you recommend & what do you do for setting up this sub. Should I get phone assistance from SVS? I have the Radio Shack SPL & Avia dvd. Thanks for your help. | ||||
| | #10 | |||||
| Re: SVS PB13 Ultra Review Quote:
Unless you have more than one sub usually leaving the phase set to 0 is best in most cases. Setting up this sub really depends on your knowledge of what the adjustments on the back do. if you leave everything at its recommended setting in the manual you still will have fairly good results. It depends on your room size and shape. Mine is 15x 35' with a 9ft ceiling. Seeing as you have the Radio Shack SPL meter & Avia DVD you have most of the tools you need I myself have not used REW yet so I cant give advice on that but just for starters setting the receivers crossover is a must with this sub as it doesn't need any help from the mains. Usually setting the crossover at 80Hz is a good start. I am still in the process of tuning it to my liking and this will be a few weeks before I have it the way I like. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #11 | ||||
| Re: SVS PB13 Ultra Review Tony, just curious what you plugged the port with. | ||||
| | #12 | ||||
| Re: SVS PB13 Ultra Review each SVS Ultra includes three foam port bungs to retune the subwoofer to: 20hz = no bungs 15hz = 1 bung 10hz = 2 bungs sealed = 3 bungs | ||||
| | #13 | ||||
| Re: SVS PB13 Ultra Review Good to know that SVS is looking after things! I just noticed in the above pic of the sub that a bung is placed in the center port. | ||||
| | #14 | ||||
| Re: SVS PB13 Ultra Review Hi Tony, Both my front and center speakers have accurate tight base response. The center speaker has frequency response of +-2 dB from 53 Hz to 18khz. Why would I not want the full voice from a TV announcer to come entirely from the center speaker in full accurate fidelity, rathar than split between the center and the subwoofer. This is what the speaker was designed to do. Likewise the front speakers have been my only speakers for the last 30 years and are capable of very accurate music reproduction. I always liked their acccurate base response. Another factor is that if I turn up the subwoofer output to accentuate the LFE effects in a movie, it might unbalance the sound coming from the other speakers. I expect to do this for demonstration purposes or even for movies with explosions. I tried the SVS PB 13 Ultra in 15 HZ mode and it sounds great, but I can't tell the difference so far from 20 Hz mode. I also balanced the output from each of my 5 speakers using my receiver's tome generator and the Radio Shack SPL meter at the center of my listening position with the meter held vertical (pointing at the ceiling). For accurate response from the subwoofer, do I use the internal tones, or is there a better method. The subwoofer is currently +8 dB more than the other speakers. If I set the speakers to 80 Hz, I will need to have the proper level between the subwoofer and the other speakers. Keep me informed as to how you personally set up your system. Thanks for your all your help. | ||||
| | #15 | |||||||
REW is ideal for this as it not only has this feature but shows you on a graph what you have. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||||
| | #16 | |||||
| | #17 | ||||
| Re: SVS PB13 Ultra Review Just to add a few things to my above review, I played some music on my system last night mostly jazz and The PB13 really does a nice job with music. I was pleasantly surprised by this as given the size I was not sure how well it would do but it sounded really smooth with nice tight bass but not too much. I don't know how SVS managed this but after re eq-ing my system to blend nicely with the sub my entire system sounds even better, the mains were very well complimented by this sub and I cant imagine how I ever did without it. The PB13 Ultra is very musical and will make any system sound far better. ![]() Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #20 | ||||
| Re: SVS PB13 Ultra Review This is my first post in here! I am looking to replace my Klipsch sub 12 with the svs pb13 ultra. I am running Klipsch rf 83 front, RC 64 center, rs 62 sides and rf 63 for the rear. All in the cherry finish except the sub and the rs 62's. and emotiva xpa 2 and xpa 5 amps. Is this a good sub for my set up the receiver right now is an onkyo 706 but looking at the onkyo 906. the room size is 20 x 30 with vaulted ceiling about 16 ft high. I am also wondering if the rosenut finish will match with the cherry finish of the klipsch. Does anyone have a picture of the rosenut up close in good quality? What about grill choices metal or cloth? Which is better or looks better? Thanks for the help. Any input on this sub will be helpful! | ||||
| | #21 | |||||
| | #22 | |||||
1: yes, it will be a fantastic sub with your (or really, any) setup. 2. IIRC, the Klipsch are more of a "light brown" kind of cherry. The SVS rosenut is very red. If they're are going to be close together, you might be better off with the black. 3. I think the metal grill is brilliant. It looks much better (IMO, of course) and is a snap to keep clean. We have several cats, a couple of them with very long hair that shed a lot, and I can't imagine keeping a cloth grill down by the ground clean. -Robb | |||||
| | #23 | ||||
| Re: SVS PB13 Ultra Review That looks really nice! Looks like it is a great match for your speakers. It looks like it is a dark red color. I think that is alot darker than the cherry Klipsch finish. I would like to get a sub in something other than black. I think the wood looks so much nicer. How is the sound? Would you know if that is a good upgrade over my Klipsch sub 12? Are there any other subs it this price range I should look at? Thanks for the help. | ||||
| | #24 | |||||
-Robb | |||||
| | #25 | ||||
| Re: SVS PB13 Ultra Review Thanks for the help. The rosenut is to red and the oak is too light. I wish they had a shade in the middle. I may have to get textured black. Can I use the sub 12 and the svs together or is that a no no!!! | ||||
