| SVSound Low frequency audio intermittentDiscuss Low frequency audio intermittent in the Manufactured Speakers and Subwoofers forum; Low frequency audio intermittent A strange problem and not sure why this is.
Last night when I was setting up my new PB13 Ultra ... |
| | #1 (Link) | |||
| Low frequency audio intermittent A strange problem and not sure why this is. Last night when I was setting up my new PB13 Ultra I was sending my receiver some test tones. The 20hz and the 30hz test tones both cut in and out about once very 3 seconds, the rest above 40hz were fine. The display on my Onkyo did not change so it seemed to be receiving something. I was using my Toshiba A2 as the CD player connected via HDMI. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #2 (Link) | |||
| Re: Low frequency audio intermittent What was the source of your test tones, DVD or CD? How loud were you playing them? Did you try the tones on a different system, or through headphones, and get the same results? Anyone with a PB13 know if it has any sort of protection limiting? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #3 (Link) | |||
| Re: Low frequency audio intermittent It was a audio CD and it has never done this befor, The level was not loud enough for the PB13 to cut out. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #5 (Link) | |||
| Re: Low frequency audio intermittent I wonder if it was vibrations caused by the low frequencies? it just seemed to timed to be that as it would play for 3 seconds and stop for 3 and then play for 3 and so on. once I went above 40hz it was fine. Edit: After further testing it is not the sub it is either the receiver or the A2 so now I need to do some more testing with another DVD player. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| What crossover frequency???? | salvasol | Home Audio Speakers | 19 | 01-26-08 12:19 AM |
| Bfd frequency bandwidth | stephenb1 | BFD Forum | 2 | 01-22-08 10:31 AM |
| BFD intermittent pop sound in sub | zamboniman | BFD Forum | 4 | 03-01-07 08:35 PM |
| Who knows about low frequency room modes? | tdamocles | REW Forum | 4 | 02-27-07 07:14 PM |
| Crossover Frequency and DB level | barun | Home Audio Speakers | 20 | 06-10-06 08:14 PM |
