Go Back   Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound
Register
SVSound
SVS SBS/SCS-01 Difference in sound?
Discuss SVS SBS/SCS-01 Difference in sound? in the Manufactured Speakers and Subwoofers forum; SVS SBS/SCS-01 Difference in sound? What does a comparison look like between having the sbs-scs-sbs fronts...... and a.... scs-scs-scs fronts......??? trying to decide between sbs ...
Old 04-17-08, 12:43 PM   #1 (Link)
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
mrsollars is offline
trying to decide between sbs and scs for my right and left fronts. your thoughts??
thanks
Old 04-17-08, 04:02 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: SVS SBS/SCS-01 Appearance
Appearance wise the SCS would be taller than the SBS. I suppose it would depend on what you want, short or tall.
Old 04-17-08, 07:22 PM   #3 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
whoops....
comparison on sound.
what does it 'look like' comparing 3 scs's across the front....vs. sbs, scs (center) and sbs......
what is the audible difference, sound quality comparison.
thanks
matt
Old 04-17-08, 10:24 PM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: SVS SBS/SCS-01 Difference in sound?
I changed the thread title. Maybe someone who has heard both will chime in.
Old 04-17-08, 11:28 PM   #5 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
thanks sonnie
Old 04-18-08, 12:52 PM   #6 (Link)
Alias: Robb
Loc: Chandler, AZ
User: #3174
Since: Oct 2006
robbroy is offline
If your budget and space allow, all SCS across the front is definitely the way to go. No question about it.
-Robb
Old 04-18-08, 01:31 PM   #7 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
is there a minimum distance between the left and right.
the problem is the corner placement....it's the only possible setup in my situation.
maybe 60inches apart (at best) is the max i could go between them.
on will be on a stand...one will sit on the hearth of the mantle....both will be approx. ear height.
also...is there a way to know how far to 'toe in or out' the left and right to cover the field.
i'll be purchasing a yamaha 663 soon. will the auto setup determine this.....or just adjust output based on distance.
thanks
matt
Old 04-24-08, 05:03 PM   #8 (Link)
New Member
Alias: Althus
Loc: Austin, TX
User: #13864
Since: Nov 2007
Althus is offline
I have gone in stages from adding the SCS all across the front and now all the way around. The sound difference is very noticable! Upgrade as your budget allows but I would def. recommend it!
Old 04-25-08, 10:41 AM   #9 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
what do you do when you upgrade like that.
what did you with your old sbs-01's??
i noticed in another thread that SVS doesn't take ''trade-in's'' (for lack of a better word) when people upgrade.
thanks.
Old 05-02-08, 03:06 PM   #10 (Link)
New Member
Alias: Althus
Loc: Austin, TX
User: #13864
Since: Nov 2007
Althus is offline
Sorry, I haven't been on here since 4/24 apparently. When I originally started buying I got the SCS and SBS fronts only. I just kept my back ones I was already using. Then bought 2 more SCS for the front and moved the SBS to the back. When I got SCS all around I just boxed the SBS to use when I upgrade my receiver to 7.1. I don't see any reason to have SCS for the 6 & 7 speakers.
I upgraded from *cough*Bose*cough* and it's been wonderful as you can imagine.
Old 05-02-08, 03:16 PM   #11 (Link)
New Member
Alias: Althus
Loc: Austin, TX
User: #13864
Since: Nov 2007
Althus is offline
mrsollars wrote: View Post
thanks
matt
If you haven't done it already, if you email SVS, techsupport@svsound.com , with your questions just like this they'll be super helpful.
Old 05-12-08, 08:39 AM   #12 (Link)
Alias: sollars
User: #19719
Since: Apr 2008
i noticed in another thread that people see 'matching' bookshelves as very important for sound quality. ie. in a 5.1 system....all 5 should match.
is there any truth to this. will i notice a difference if i use LCR scs-01's and surround sbs-01's??
any further info is appreciated.
thanks
matt
ps. still struggling with the sub decision. pb-12 nsd vs. 20-39 pci vs. 20-39 pc-plus vs. pb12-plus/2 vs. pb12-plus.....and on and on.
Old 05-12-08, 09:07 AM   #13 (Link)
New Member
Alias: Althus
Loc: Austin, TX
User: #13864
Since: Nov 2007
Althus is offline
In movie playback, it's noticeable but not as much and if that's most of your listening then stick with that config. But if you play hi-rez surround music, then it is very noticeable. Basically, yes, you will notice a difference. You just have to decide how important it is to you and your listening habits. Personally I'd highly recommend it.
Email SVS on the sub decision. You can give them your room dimensions and other info. and they can really help you a lot.
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
SVS sbs-01 speaker stand question vv132 SVSound 4 06-10-08 10:49 AM
SVS SBS/SCS-01 Home Theater Ensemble: Good Things Come in Small Packages Wayne A. Pflughaupt Home Audio Speakers 5 05-30-08 02:54 PM
SVS SBS-01 & PB12-NSD review - Audiophile.no (English version) L-Sound - Jan SVSound 1 05-28-07 02:53 PM
SVS SBS/SCS-01 Home Theater Ensemble: Good Things Come in Small Packages Wayne A. Pflughaupt SVSound 1 04-29-07 03:53 PM
SVS 25-31 PC-Plus Subwoofer with SVS SBS-01 5.0 package = Enormous Bang For the Buck! Kipp Jones SVSound 1 02-11-07 08:04 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
