Go Back   Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound
Register
SVSound
PB12-NSD On Its Way
Discuss PB12-NSD On Its Way in the Manufactured Speakers and Subwoofers forum; PB12-NSD On Its Way I ordered a PB12-NSD Tuesday. It's on time and scheduled to arrive tomorrow (Friday). I'm impressed! Deciding ...
Old 05-08-08, 11:35 AM   #1 (Link)
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
DougMac is offline
PB12-NSD On Its Way
Deciding on a subwoofer for our dedicated HT that's under construction has been a long and tortuous journey. I've been all over the map, from considering retail subs to DIY.
I had settled on a DIY using a Rhythmik 15" servo. The problem is I'm doing the HT construction and this would just add to my task load. For ~$100 more than the raw driver and amp, I could get a PB12-NSD. That tipped the scales and I ordered.
As soon as I get it, I'll post impressions. I'll get some of the obligatory comments out of the way now:
Wow! It's big! It's heavy!
Doug
Old 05-09-08, 07:10 AM   #2 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is online now
Re: PB12-NSD On Its Way
Looking forward to your impressions on the SVS Doug....thanks for taking care of the 'obligatories' up front!
Old 05-10-08, 09:28 AM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
Congrats Doug... and I also look forward to your impressions.
Old 05-11-08, 01:45 PM   #4 (Link)
New Member
Alias: thomson405
Loc: Oklahoma City, OK
User: #20602
Since: May 2008
thomson405 is offline
Lucky dog!!
Old 05-12-08, 07:24 PM   #5 (Link)
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
DougMac is offline
It's Here!
Brown got here about 6:45. He helped me carry it in. Nice guy!
Initial impressions:
First, my only point of reference is my 20 year old Infinity SV-10 servo that just bit the dust. It wasn't a bad little guy, but was pretty much a one note honker. Also, the HT is not done. I've got it sitting upstairs in the great room. It's hardly a fair test. The area is 24wx40lx22h. At the back there's a loft over the hall and bedroom that's 24wx24lx12h, so there's an open space 24x60'. You do the math for the volume.
I fired it up and well, it sounded just OK. I haven't done a formal setup, but with about 20 minutes of tweaking it just came alive! I adjusted the phase, moved it a little, but I'm restricted, and did a quick and dirty volume balance. I'm feeding it with an NAD T762. If you set the mains to large, it turns of the feed to the sub when using low level. I set the mains to small, crossover at 80. It sounded OK with my mains, but not great. I then changed the crossover to 60 and everything fell into place. The blend was much better and it helped with clarity.
We Netflix and own few DVD's, so I won't be able to run through the usual suspects. I do have Nemo and played the Abyss and Darla! Wow, there must be a lot of sub 30hz energy in Darla. I was completely different from the little Infinity. I also played the opening to "The Lion King". The far off herd was much clearer and when they cut to the elephants, instead of some amorphous boom! boom!, you can actually hear the footfalls.
Music sounds great. I played some James Taylor, Squirrel Nut Zippers and I'm now listening to Strauss' Zarathustra. The opening pedal note is very deep and controlled. Double basses now have the proper low support. I'd say it's a musical sub, whatever that means.
I can't wait to finish the HT and properly tune it. I'm sure it will sound wonderful in a more controlled environment.
It's a keeper for sure.
Doug
Old 05-12-08, 07:50 PM   #6 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is online now
Wow that's a big space....glad it's going in a smaller room! What are the dimensions of your HT space?
Thanks for the initial impressions Doug. Keep us posted as things progress.
Old 05-12-08, 09:05 PM   #7 (Link)
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
DougMac is offline
chas wrote: View Post
The HT is 16wx18lx9h. From what I've read that's pretty close to ideal ratios. It's an enclosed space. There is, however, a refreshment area space in the back left that's 6wx10dx9h.
You can see the construction here:
http://picasaweb.google.com/dougbrucemac/HomeTheater
All framing done by me, mostly alone, although Deb helped a little while not studying for her Doctorate.
Doug
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
Dual PB10-NSD or one PB12-NSD/2 chas SVSound 17 01-18-08 10:54 PM
Pc13 + Pb12-nsd = alexadams77 SVSound 10 11-16-07 12:37 PM
Svs PB12-NSD Ilkka Subwoofer Tests 6 07-30-07 12:49 PM
For my size room PB12-NSD or PB10-NSD vv132 SVSound 1 07-30-07 11:22 AM
PB12-NSD vs PB12Plus/2 Malice SVSound 25 02-25-07 09:57 AM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
Search Engine Friendly URLs by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173
