| SVSound Current (12.3) THD tests run on 20-39 PC+...?Discuss Current (12.3) THD tests run on 20-39 PC+...? in the Manufactured Speakers and Subwoofers forum; Current (12.3) THD tests run on 20-39 PC+...? Hi all,
I have been looking for FR and THD graphs for a 20-39 PC+ using the new 12.3 drivers. ... |
| | #1 (Link) | |||
| Current (12.3) THD tests run on 20-39 PC+...? Hi all, I have been looking for FR and THD graphs for a 20-39 PC+ using the new 12.3 drivers. Iikka has results posted for a PB12 Plus/2 with 12.3 drivers, and since I have a pair of 20-39 cylinders, is that relatively close? Somewhere I read that the new 12.3 drivers are very close to the current Ultra driver (in the same vein as the new NSD driver being very close to the 12.2?), and I did find THD tests dated May, 2005 on a PC-Ultra cylinder over at AV talk. Thanx! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... Last edited by Vader; 08-11-06 at 02:50 PM. | |||
| | #2 (Link) | |||
| Re: Current (12.3) THD tests run on 20-39 PC+...? So difficult question that nobody has replied for more than 6 months. IMO, it is not possible to guess what would the THD graphs look like based on another driver... even if they are close enough in SPL capabilities. It is difficult to compare THD of dual 20-39 PC plus subs agains Illka's Plus/2 tests, as although both options have 2 * 12.3 drivers, they don't have the same power and enclosure volume.... but what should be expected is that for the same SPL levels, the dual 20-39 would have less distortion than the plus/2. I think the 20-39 PC+ unit should be tested to have a precise idea. Maybe you can ask Tom V. to enlighten you on this!! B Rgds Blaser | |||
| | #3 (Link) | |||
| Re: Current (12.3) THD tests run on 20-39 PC+...? Based on explanations from Ilkka, Ed, and Ron over over the last few months, I have come to conclude the same thing: that I cannot use the PB12 Plus/2 as a guide (well, maybe a rough one). Ilkka posted that he did test the 20-39 PC+ (12.2), but has not yet posted the results, which I am waiting for (at least, they will be very close to the 12.3 I am thinking). For now, I am using the results for the 25-31 cylinder (25Hz) as an approximate guide, just shifting the whole thing to the left to account for the lower native tuning frequency. In any case, it is only wanting to learn the most I can about my equipment and how to get the most from them... Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them. Hmmmmm.... SVS..... No Bass Left Behind.... | |||
| | #4 (Link) | |||
| Re: Current (12.3) THD tests run on 20-39 PC+...? Though I will post the full results soon, here's a little preview for you. Add 6 dB if you have co-located duals. The 12.3 will be really close, probably around 1 dB more in upper bass range. ![]() ![]() | |||
| | #5 (Link) | |||
| Re: Current (12.3) THD tests run on 20-39 PC+...? Hi Vader!! Yeah you're right!! Even the PB12+ has not been tested by Illka... Let's wait and see the 12.2 driver results I'm impatient to see them also..Hey Illka, We are waiting impatiently!!Let's have the results Blaser | |||
| | #7 (Link) | ||||
| Re: Current (12.3) THD tests run on 20-39 PC+...? Quote:
I think the 12.3 unit will have also 3-4 db less SPL at 20 Hz in the FR (compared to the db 12.2), but Max SPL will remain the same though Blaser | ||||
| | #8 (Link) | |||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Subwoofer Tests Explained | Ilkka | Subwoofer Tests | 15 | 08-13-07 08:11 AM |
| SVS PB12-Plus/2 20 Hz tune (Plus 12.3) | Ilkka | Subwoofer Tests | 21 | 03-24-07 06:38 PM |
| Blind tests done for 2 AVRs and a Pre-Pro. | bobgpsr | Home Theater Components | 40 | 10-10-06 01:51 PM |
| SVS PB12-Plus/2 25 Hz tune (Plus 12.3) | Ilkka | Subwoofer Tests | 3 | 07-17-06 02:14 PM |
| Subwoofer Tests Round 3, 6-7th of May 2006, Test Summary | Ilkka | Subwoofer Tests | 0 | 07-16-06 01:36 PM |
