Hello guys I'm building a new home theater and need some help. Looking at the ultra towers center and then prime sats for rears. Or the ultra bookshelf center and ultra surrounds. My room is 17x20 and I will be using an pb-1000 that I had previously. What would be better ? And I have a marantz 7008. Thanks for the help in advance.
I think that's a great idea. The more information you have, the better. Plus, who knows SVS like SVS? I suspect you'll end up with a prime system, with a pair of 2000 series subs. Haven't done the math etc, but I know you get multiple sub discounts, and who knows, they might have some B-stock or blems to help the budget. Fwiw, I think if you go that route, and take the time to set it up, you will have a real nice setup. Good luck.
The klipsch premier will be easier to drive and may have "slightly" better highs however with the Prime towers having a dedicated mid range driver it will have a better (smoother) frequency response across the mids.
The svs scs would make great surround speakers, That would save you money to upgrade your mains center and subs. I would not replace them just move them to your surrounds.
Good choice. Kids are trainable. And they do grow up fast!
Sent from my iPhone using Tapatalk
Related Threads
742.3K posts
170.9K members
Since 2006
