80 is a pretty good number to start with. You can adjust to taste, but you'll probably find it works good. I have experience with the sb2k. It is an absolutely spectacular sub. As long as the room isn't too big, in which case it just doesn't have enough output. It is smooth and articulate, and sounds great. Are you using it with the sb1k?
The towers sound really good. Don't have the sub hooked up yet. The towers by its self make movies sound awesome I'm hearing things that iv not herd before in a movie. My room is not very optimal lol.
I didn't have time before, but I should say its worth experimenting. That way you'll know more about your system, and have more reference points. I would at least try different XO points just to see.
Sent from my iPhone using Tapatalk
Related Threads
742.3K posts
170.9K members
Since 2006
