SVSoundDiscuss Ultra levels in the Manufactured Speakers | DIY Subwoofers forum; Ultra levels Hello, I have a question...I have read setting up your HT 101 I think on AVS forum, and it was ... |
Views: 445 - Replies: 2
| Ultra levels Hello, I have a question...I have read setting up your HT 101 I think on AVS forum, and it was an article or post by Ed Mullen and he was saying when setting up the sub it is suggested to leaving the AVR SW level at -5db. Obviously we all like more to a certain point above the mains, so you would just raise the gain to your liking? How do you Ultra owners set yours up? Most of the movies I own the level can stay consistant but of I throw in WOTW I find I have to turn it down as to not overdrive the woofer and damage it. The room is fairly small 110 sqft and I know this Ultra is used in far, far , far larger rooms than mine. Where is the limit I can go with this. BTW I am still a HT newb so I am still learning proper calibration. Pioneer VSX-1018AH Sony BDP-S550 Polk Audio TSi 500 - L/R Polk Audio TSi CS20 - C Polk Audio Monitor50 - SR/SL JBL J2080 - SBR/SBL 2 x SVS PB13-ULTRA / 2 x PC13 - Ultra 110 sq ft room Feel the SVS! | ||||
| | #2 | ||||
| Re: Ultra levels One point you should know especially when watching WOTW is that DTS is recorded much hotter than Dolby Digital. I have learned this from bitter experience and 2 blown speakers!! I would set your level to Dolby reference (75db) and then adjust according to your tastes. Your goal should be clean bass, not just loud bass. Hope this helps, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, High fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Onkyo TX-SR707 7.2 Receiver w/AudysseyXT Panasonic DMP-BD605 Blu-Ray player Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #3 | |||||
| Re: Ultra levels Quote:
Ed Mullen is fairly accurate that a sub level should not be hot coming from the receiver. running it hot can clip the input of the amp during the really loud portions of movies. There are many movies that have subsonic frequencies with the uncompressed audio (below 10Hz) that will over drive a sub WOTW is one movie the new Hulk movie is another. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
