| SVSound Fathom 113Discuss Fathom 113 in the Manufactured Speakers and Subwoofers forum; Fathom 113 Thinking about an additional sub. I have the Fathom 113 sounds great. Really pleased with it's performance.
Unfortunately right now ... |
Views: 620 - Replies: 12
| Fathom 113 Thinking about an additional sub. I have the Fathom 113 sounds great. Really pleased with it's performance. Unfortunately right now I don't have the funds for another Fathom. Is it a mistake to mix different type subs? I was thinking about a cyclinder sub from SVS. My room size is twenty-five feet by thirteen feet with seven and a half foot ceilings. What can I say I love bass. Thanks in advance for any thoughts. ![]() Frank Infocus 7205,Da Lite Screen Outlaw 990/7700 B&W 804's mains,HTM3S center,3-DS7's surrounds,Fathom 113 subwoofer Sony 550 Blu-Ray player Sony 777 DVD player,Toshiba DVD player MX 3000 remote,Monster 3500,3600 conditioners Comcast, MIT & Monster cable http://community.webshots.com/user/rubbersoul662001 | ||||
| | #2 | ||||
| Re: Fathom 113 Sometimes it can be done, but alot of times mixing starts to muddy things, especially if your mixing 2 different alignments, ported and sealed. I think you will lose the clarity of what the F113 brings to the plate. So far I have had good luck running 3 - 18" Maelstrom-X's plus a 15" TC-2000 in the same room. I am extremely happy with the results.... But they are all sealed. | ||||
| | #3 | ||||
| Re: Fathom 113 I have a pair of IXL-18's and a pair of Atlas 15's in the same room with no issues. | ||||
| | #4 | ||||
| Re: Fathom 113 I don't think a different sub would be a problem. Have fun. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #7 | ||||
| Re: Fathom 113 Why not just a second 113? I think it should be pretty satisfying with 2 in that size of room Otherwise, I think it would work fine mixing two subs, it's really all about how you place them anyway. | ||||
| | #8 | ||||
| Re: Fathom 113 I guess I forgot to add to this that you should probably stick with the same alignment, ie sealed like the f113 if your going to add another sub.... How about adding a DIY sub like a good 15" or even something like a 18" Maelstrom-X, it would be a great project for you, and can be reasonably done from a price perspective. It is enlightening how much you can learn and save.... I love my F112, and will keep it forever, but you could sell that F113 and build 2 subs and almost walk away for even money... ![]() | ||||
| | #12 | ||||
| Re: Fathom 113 I'm taking a stab that the OP has made a decision over the last 4 months, but if not or others are in the same position SVS is oming out with higher end sealed subs. The SB13Plus and SB16-Ultra, dates are fuzzy but I once heard as soon as October for the SB13-Plus. They look interesting and with SVS's reputation should provide a pretty bombastic experience for less money that your Fathom. Otherwise, like others have said, a sealed PB13-Ultra should still match up pretty well with you F113. | ||||
| | #13 | ||||
| Re: Fathom 113 It seems that mixing subs gets a lot of frowning upon in theory, but from people that actually do it, they have now problems (assuming similar quality). Has anyone tried mixing subs and actually did not like it? | ||||
