Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
SBS-01: A review from foreign parts.
Discuss SBS-01: A review from foreign parts. in the Manufactured Speakers and Subwoofers forum; SBS-01: A review from foreign parts. Kent Home Cinema threw an open day on Saturday for the members of AVForums.com in the UK. The SB-12 was ...
Views: 1900 - Replies: 0
Old 09-17-06, 04:11 PM   #1
Alias: Russell
Loc: Cambridge, UK
User: #494
  russ.will is offline
Kent Home Cinema threw an open day on Saturday for the members of AVForums.com in the UK. The SB-12 was the reason, although the SBS-01s were ever present as were the PB-10 and PB-12/plus. We don't get the Ultras (yet).
This is a direct copy of my post from the above forum and I thought I'd copy it here. Please bear in mind the European market is different to the US market due to room sizes. The SB-12 is a result of European demand and the market is awash with small satellite speakers due to their high WAF in small rooms.
Please bare this in mind when reading this and note that this is also why this review starts off answering a question that hasn't been asked. It has, just not here!.......
I thought them to be exceptional value for the money and in my opinion, they would still be exceptional value with wood veneer and a price hike.
That tweeter is a peach. It's not up there with the Esotars and Revelators of this world, but given that one of those by it's self would cost as much as an entire SBS-01, that is in no way damning with faint praise.
I made sure scene 2 from The House Of Flying Daggers got a run out, as much to test the SBS-01s as the SB-12/PLUS. THOFD has a razor sharp, hugely dynamic DTS soundtrack, that doesn't suffer from overblown bass effects nor a preponderance of synthesised sounds that make all systems sound good. A true reference IMHO.
There are several sounds, (the massed bean drop, the shattering glass bowl, the sword from the scabbard and any number of sword fights) that can tip an already edgy speaker over the edge into harshness, especially when driven hard and yesterday, speakers were being driven hard. Furthermore, it's a soundtrack with realistic sounds that demand a realistic presentation to sound effective. To my mind it's the real world sounds that separate the men from the boys. Trying to judge speakers/subs with War Of The Worlds, is like trying to judge projectors with Finding Nemo. You know what a real drum sounds like, just like you know a realistic skin tone. WOTW and Nemo have neither.
The SBS-01 suffered from none of these potential problems to any great degree. At high volumes, dynamics lept out uncompressed, speech remained intelligable and sibilance never reared it's head to any great degree. Remember, this was a hard surfaced room with nowt but the mass of Forumites squishy bodies to damp reflections, so it would have been easy to excuse any tendancies toward brightness.
I also spent a good half hour with them in the smaller PB-10 room and ran some Blue Man Group, Pink Floyd and a selection of Hayes' bassy 'pop tunes' through them and feel the doubts about their musical ability, to be largely unfounded. Snappy attack, wide and deep sound stage and bounce along with good timing and they're not too bad on the cabinet colouration front.
This is all with respect to their price, for movies at least the M&K S-150s down stairs were in a different class. But they were certainly the equal of my Kefs and in the case of the center speaker, altogether superior. The treble quality drawing my attention in particular and the fact that it is a true center design, correctly sized for it's duties.
The downsides? They're small, they're not small enough and the MTS-01s are just around the corner.
Small? - Loud music started to show their ultimate volume limitations as the small driver was achieving quite large driver exscursions and with music at least this heralded the sound starting to shut in slightly and loose it's coherance a touch. Vocals started to sound a bit 'cupped hand'. A little restraint with the volume control is all that's required and I did not notice this trait to the same degree with movies. It may be because music relies on the L&R to step up their contribution a bit relative to the center which normally carries the mother load.
Not small enough? - You're going to struggle to get the the sub/sat crowd to jump up to something this size. The performace advantages they hold are clear, but they're bigger than Quad L-ites, and without the finish options. They just don't have the WAF of the true sattelites against which they are priced. They fall between two stools, which leads me to....
.... MTS-01s? SVS's first attempt at a speaker causes me some excitement at their next. Most people will have to stand mount the front pair and budgeting for stands makes you ask if some of the small form factor floorstanders offer better value. They certainly look better than stand mounts in a domestic setting. The prospect of extra drivers for improved high volume level performance, the addition of real wood finishes (and SVS are VERY good at these) and the looks of a tower speaker, leave me dribbling with excitement like an old cat.
All in all, the story is similar to that of the SB-12. Astonishing VFM, but if you can afford and accomodate larger, then you probably will. If you can't, then here are two products that reduce the compromise this used to mean and that can only be good.
Russell
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
