Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
Do the PB13-Ultra or the PC13-Ultra "dance around" on the floor?
Discuss Do the PB13-Ultra or the PC13-Ultra "dance around" on the floor? in the Manufactured Speakers and Subwoofers forum; Do the PB13-Ultra or the PC13-Ultra "dance around" on the floor? Since I currently do not have a subwoofer, I run my Klipsch RF-7s as Large and the rest of my ...
Views: 709 - Replies: 15
Old 04-11-09, 08:16 AM   #1
Alias: Kain
Loc: Dubai, UAE
User: #34732
Since: Mar 2009
  Kain is offline
Since I currently do not have a subwoofer, I run my Klipsch RF-7s as Large and the rest of my speakers as Small. At -15 dB on the volume nob, if I play the THX intro at the beginning of the newer Star Wars movies, the woofers on my RF-7s move A LOT. The bass that comes from the RF-7s at these volumes is pretty much subwoofer like. If I watch a bass-heavy movie at -15 dB or higher on the volume nob, my RF-7s start to move around on my tiled floor. My RF-7s weigh 90 pounds each.
Since the PB13-Ultra weighs 155 pounds, I doubt it will move or "dance around" at high volumes. Am I correct? But what about the PC13-Ultra? It also weighs 90 pounds like my main speakers and will it also "dance around" like my RF-7s on my tiled floor?
Old 04-11-09, 08:56 AM   #2
SVSound
Alias: Ed
Loc: Upstate New York
User: #1779
  Ed Mullen is offline
Re: Do the PB13-Ultra or the PC13-Ultra "dance around" on the floor?
Kain wrote: View Post
Since the woofer reactive forces are oriented in the vertical axis in the PC13-Ultra, you might get a bit of base plate hop on a hard tile floor at very high playback levels.
If this occurs you could use a GRAMMA under the base plate, or you could install the optional 3M half-circle rubber feet. We send even send you extras if needed and basically you populate the bottom of the base plate with them and that will provide a more compliant and damped foor interface than the standard hard rubber discs.
FWIW, the RF-7 is not considered a full-range speaker (at least not for HT applications), and will sound and perform much better when set to Small with a 40-60 Hz crossover and a subwoofer in the loop.
Ed Mullen
Product Development Manager / Customer Service Director
SV Sound, LLC
www.svsound.com
sales@svsound.com
techsupport@svsound.com
"What We Do In Life, Echoes In Eternity"
Old 04-22-09, 10:20 PM   #3
Alias: Quenten
Loc: Tallahassee, Florida
User: #9895
Since: Jun 2007
  Tonto is offline
I've had my PB 13 in the living room for about 2 years sitting on ceramic tile. Yesterday after a buddy & I got back from turkey hunting, I popped in a disc to show him what a sub sounds like. He looked up & said "that thing shakes your whole house"! The point is, with things rattling & shaking as they always do...my sub has always stay'd put. And thats with it sitting straight on the floor. I can't immagine you'll have any issues.
Old 04-22-09, 10:40 PM   #4
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
  bonehead848 is offline
155 pounds is huge. I imagine you would have to damage your hearing before you could move that beast.
Old 04-23-09, 01:51 PM   #5
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
My PB13U sits on a concrete floor with carpet on top and I have had it move around a little bit during some movies but for the most part it has never moved more than an inch or so. The big thing is I cant use it as a table for anything as any items I have ever placed on top of it moves around alot.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 04-24-09, 09:09 AM   #6
Alias: Robb
Loc: Chandler, AZ
User: #3174
Since: Oct 2006
  robbroy is offline
tonyvdb wrote: View Post
Interesting. I have stuff on top of mine and neither has moved at all (I do have thin foam between anything hard that is on top of the sub). I can't even imagine how loud I'd have to go to get one to move (even when I only had one). Mine is also on carpeted concrete slab.
-Robb
Old 04-24-09, 08:07 PM   #7
New Member
Alias: Berty52
Loc: Sherbrooke, Québec
User: #676
  berty52 is offline
My PC-Ultra used to dance in the first month of use but after I put a rubber mat under it it stayed right at it's place.
Old 06-14-09, 02:49 PM   #8
Alias: reddevil
Thunderheader's Avatar
Loc: Edmonton, Alberta Canada
User: #32737
Since: Jan 2009
  Thunderheader is offline
I cuurently have 2xpb13-ultras and 1xpc-ultra soon to have one more pc-ultra and I have never seen any of them move. I have hardwood floors, and with rubber feet that is on the bottom of them they are hard enough to move around as it is.
Posted via Mobile Device
Old 06-17-09, 09:55 PM   #9
Alias: Erle
epereira's Avatar
Loc: Detroit
User: #20680
Since: May 2008
  epereira is offline
I have a PC-13 Ultra and have not experienced any hopping around (even at relatively high volumes) though my neighbors have come a-knocking on my door . I have since started using a Auralex SubDude to help dampen the vibrations and have not had a complaint since then.
Old 07-16-09, 06:13 PM   #10
Alias: Ray
Loc: Kingwood
User: #39582
Since: Jul 2009
  Ray in Kingwood is offline
Pardon my total ignorance but what is a GRAMMA??
Old 07-16-09, 06:36 PM   #11
Alias: Erle
epereira's Avatar
Loc: Detroit
User: #20680
Since: May 2008
  epereira is offline
The GRAMMA is a sound isolation/dampening pad that sits under the subwoofer or amp to dampen the vibrations. More information is available at the Auralex website:
http://www.auralex.com/sound_isolati...ion_gramma.asp
"The GRAMMA (Gig and Recording, Amp and Monitor, Modulation Attenuator) is an incredibly effective patented device that's used to float an amp or loudspeaker."
Old 07-16-09, 07:12 PM   #12
Alias: Ray
Loc: Kingwood
User: #39582
Since: Jul 2009
Thank you Sir, most appreciated.
Old 07-16-09, 07:13 PM   #13
Alias: Ray
Loc: Kingwood
User: #39582
Since: Jul 2009
Now I know
Old 09-05-09, 11:56 AM   #14
Alias: Ben
Loc: Yaphank, NY
User: #466
  eyecatcher127 is offline
Has anyone tried the aualex products in a home with traditional carpet floors? I'm curious if it assists in dampening to hear any more audible clarity. Right now i have the PB 13 ultra sitting right on the carpet floor.
Old 09-17-09, 05:33 PM   #15
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is offline
eyecatcher127 wrote: View Post
I have used the Auralex grammas before on carpeted floors and did not see any benefits from having them, I also had some custom made platforms made for the DD series that I owned, but again NO real benefits for my setup, but on solid floors or raised flooring I imagine they would help...
Antec BD HTPC 4.5tb - Oppo BDP 83(MR) - 46" LCD 1080p - Arcam FMJ AV888 - Rotel RMB-1575 - M&K S150THX LCR - M&K CS29's - M&K MX5100SF...
Old 09-18-09, 12:51 AM   #16
Alias: Ben
Loc: Yaphank, NY
User: #466
Thanks. for the info.
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
"dance, around", floor?, pb13-ultra, pc13-ultra
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
