Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
AS-EQ1 SubEQ function in 2 Channel audio setup.
Discuss AS-EQ1 SubEQ function in 2 Channel audio setup. in the Manufactured Speakers and Subwoofers forum; AS-EQ1 SubEQ function in 2 Channel audio setup. Hi, I am considering purchasing the AS-EQ1. I have a relatively complete understanding of setup and the performance improvement the ...
Views: 321 - Replies: 5
Old 06-16-09, 02:06 AM   #1
New Member
Alias: Mark
Loc: Tucson, AZ
User: #24449
Since: Aug 2008
  loc4me is offline
Hi,
I am considering purchasing the AS-EQ1. I have a relatively complete understanding of setup and the performance improvement the AS-EQ1 will provide in my Home theater setup. I am a wondering though if a second one in could function in the following situation.
I have a Peachtree Audio Decco running as a preamp feeding a Sumo Andromeda III power amp from its stereo pre-outs. The Sumo is powering a set of AV123 Strata Minis. The Strata Minis are a 4 way speaker that can accept high level in to feed the powered 8 inch woofers or can be fed from sub/stereo pre-outs.
In my listening room I get resonances from the powered woofers. Would the AS-EQ1 function properly if It was somehow in the signal chain between the preamp and the woofers? I am worried that I only have one set of pre-outs to feed the power amp and the AS-EQ1.
I would appreciate any feedback if you guys think this product would work well in this situation or if another product would. If you feel this is exactly what the AS-EQ1 was designed to do, I would appreciate some setup help and the best way to do it.
Thanks.
I have also sent an email directly to SVSound's tech support asking the same question.
Old 06-16-09, 08:46 AM   #2
SVSound
Alias: Ed
Loc: Upstate New York
User: #1779
  Ed Mullen is offline
Re: AS-EQ1 SubEQ function in 2 Channel audio setup.
loc4me wrote: View Post
Hi,
Thanks.
I'll answer your note here, and then send a dup from Tech Support to close the loop there.
The AS-EQ1 can be used in this application - send the L pre-out to Sub A input and the R pre-out to Sub B input, and then direct the Sub A/B outputs to their respective speaker inputs.
The AS-EQ1 will detect both the electric/acoustic high pass (where the woofers roll-off down deep) and electric low pass (from the active crossover and or internal low pass in the powered amp). In essence, it will treat your powered woofer section as two discreet subwoofers, each with its own amp.
The only caveat is the fixed latency in the AS-EQ1, which is 7.5 ms. So in order to keep your powered woofers in phase with the remainder of your speakers, the feed to the loudspeaker amp must be delayed 7.5 ms. This can be accomplished with a digital delay device (such as a Behringer DCX2496 or equivalent). Unless you are willing to delay the loudspeaker feed by 7.5 ms, I don't recommend using the AS-EQ1 in a stereo application.
Ed Mullen
Product Development Manager / Customer Service Director
SV Sound, LLC
www.svsound.com
sales@svsound.com
techsupport@svsound.com
"What We Do In Life, Echoes In Eternity"
Last edited by Ed Mullen; 06-16-09 at 09:13 AM.. Reason: Clarified latency statement
Old 06-16-09, 09:32 AM   #3
SVSound
Alias: Ed
User: #1779
I want to clarify the difference between the AS-EQ1 electrical latency and the distance value it generates for input into the AVR or pre/pro, because the two values are not the same.
The AS-EQ1 will measure the amount of time it takes for the subwoofer ping to reach the mic. It will then convert that time value into a distance value for the user to input into the AVR. This is done with a standard conversion value using the speed of sound at sea level (1125 ft/sec). So if the AS-EQ1 measures a total delay of say 13 ms between the subwoofer ping and the sound actually reaching the mic, that will equate to an 14.6 foot distance value to input into the AVR.
The actual electrical latency of the AS-EQ1 is 7.5 ms, which equates to an 8.4 foot distance value. The two numbers are not the same and are not interchangeable. So for the 2-channel user who does not own a surround sound processor with distance values and who actually needs to delay the amp feed to his loudspeakers, he should input 7.5 ms into the delay device.
This assumes the subwoofer and the loudspeakers are in the same plane and are the same distance to the listening position. If the subwoofer is closer or farther than the speakers, provide us with the distance differential, and we can calculate the exact delay value to input into your delay device for 2-channel applications.
Ed Mullen
SV Sound, LLC
www.svsound.com
sales@svsound.com
Old 06-16-09, 12:33 PM   #4
New Member
Alias: Mark
Loc: Tucson, AZ
User: #24449
Since: Aug 2008
  loc4me is offline
Ed,
Thanks very much for the clear explanation of how the AS-EQ1 will function in this situation. It is clear to me that the AS-EQ1 will work perfectly in my home theater. I will be purchasing one for that system. I am still looking for a viable solution for my two channel system.
Thanks again for the detailed response.
Old 06-16-09, 01:13 PM   #5
SVSound
Alias: Ed
User: #1779
You are most welcome. As an aside, any EQ device will introduce some amount of latency, so you are better off EQ'ing the entire loudspeaker rather than just one driver and only a portion of the operating bandwidth. Then any latency becomes a non-issue. Something like the stand-alone Audyssey Sound Equalizer would be a suitable device for your application.
Ed Mullen
SV Sound, LLC
www.svsound.com
sales@svsound.com
Old 06-17-09, 06:50 AM   #6
Alias: Richard
spearmint's Avatar
Loc: Melbourne, Australia
User: #131
  spearmint is offline
Thanks Ed for a very informative couple of posts. These posts should be put on your web site IMO, they will answer this question for thousands of 2ch enthusiasts around the globe.
Cheers Minty
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
as-eq1, audio, channel, function, setup., subeq
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
