Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Manufactured Speakers | Subwoofers > SVSound
SVSound
  Discuss Help Please in the Manufactured Speakers | Subwoofers forum; Help Please Hi, My equipment Samsung Series 5 50" plasma Pioneer 2016AVS receiver Pioneer DV-410V DVD player BFD SVS PB-12NSD I recently ...
Views: 318 - Replies: 5
Old 08-23-09, 06:06 PM   #1
Alias: rudra
rudra's Avatar
Loc: Sydney Australia
User: #16315
Since: Feb 2008
  rudra is offline
Help Please
Hi,
My equipment
BFD
SVS PB-12NSD
I recently purchased a PB-12NSD sub about 2 months ago. I have calibrated it and EQed the sub with REW & BFD. All my equipment is connected to a Belkin PureAV PF60 power unit. I had the same setup with a Jamo sub. The equipment starts in a sequence,BFD->AMP->SUB. When I put the amp in to standby after 15 secs I hear a noise from the amp for about 2 secs. I did not have this issue before and checked all the cables to make sure something wasn't loose. What baffles me is that the noise does not come when the amp is put into standby mode. It take about 10-15 secs and I can see that the monitor lights on the BFD light up. I haven't tried connecting the sub directly to the amp. I will go home tonight and see if that makes a difference.
Thanks in advance.
Cheers
VJ
Old 08-23-09, 06:50 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Help Please
Are you sure that the Belkin can handle the draw of the amp and sub together? When you say AMP are you using a receiver or a dedicated amp? The PB12 has its own built in amp doesn't it?
Home theater:
Onkyo TXSR805, Samson Servo 300 amp
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Panasonic BD60, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 08-23-09, 06:57 PM   #3
Alias: rudra
rudra's Avatar
User: #16315
Since: Feb 2008
  rudra is offline
Re: Help Please
Tony,
I apologize for the ambiquity. I have a receiver and its power consumption is about 400 watts. I live in Australia where we have 240V.
Old 08-23-09, 09:02 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Help Please
Ok, so your saying the the PB12 hums when it is turned off or the BFD is turned off? how do you have it connected to the receivers output, through the BFD? I wonder if the BFD is getting rid of some residual noise and if so it should not be doing so. I would try bypassing it to see if the noise goes away.
Home theater:
Two Channel system:
My Webpage
Old 08-23-09, 11:34 PM   #5
Alias: rudra
rudra's Avatar
User: #16315
Since: Feb 2008
  rudra is offline
Re: Help Please
The sub does not hum. I sounds like a "power" click if that makes sense. The connection is XLR-RCA from the receiver to the BFD. XLR-RCA from the BFD to the sub. When I get home I will try to bypass the BFD and see if the noise goes away. This happens when the reciever is put in to standby. At this stage the BFD & the Sub still have the power.
Old 08-24-09, 06:12 AM   #6
Alias: rudra
rudra's Avatar
User: #16315
Since: Feb 2008
  rudra is offline
Re: Help Please
Tony
I bypassed the BFD and the noise goes away. The noise come after 1min 1sec exactly and it come everytime I put the receiver into standby. Do you reckon that the BFD is faulty.
« Home Theater Shack > Manufactured Speakers | Subwoofers > SVSound »
Bookmark and Share
Dish Network
