give brief spec differences between PB2-Plus and PB13-Ultra. welcome to correct if I am wrong.:nerd:
SVS PB2-Plus [in 2004/Oct renamed to PB12-Plus/2], $1599, piano gloss.
# Exclusive SVS 12.3 high-output woofer X 2:yikes:
# 900 watt BASH amp with room PEQ compensation:devil:
# Down-firing configuration
# 4" high-flow flared port CURVE tuning X 3
# Made in the Ohio SVS factory with USA made parts:sn:
# Selectable Hz modes, down to 16Hz
All built in the USA, its cutting-edge (and incredibly durable) cured exterior finish takes longer to ready in the high humidity present. :clap:
SVS PB13-Ultra, $1599.
# Exclusive SVS Ultra-13" high-output woofer X 1:crying:
# 750 watt BASH amp with room compensation:rolleyesno:
# Front-firing configuration
# 3.5" high-flow flared ports CURVE tuning X 3
# Assembled in the Ohio SVS factory with foreign made parts:hissyfit:
# Selectable Hz modes, down to 10Hz
from my understanding, PB2-Plus mainly uses USA made parts, but new PB13-Ultra changes to more China made parts [includes cabinet]. thus SVS deleted 'made in USA' from carton.:huh:
made in USA
made in USA 2
so folks, which sub performs better?
which one will you buy, assume both are still available?
made in USA
made in USA 2
