| SVSound PB12-NSD vs PB12Plus/2Discuss PB12-NSD vs PB12Plus/2 in the Manufactured Speakers and Subwoofers forum; PB12-NSD vs PB12Plus/2 Hi,
I was thinking about an upgrade from my PB12-ISD (with an NSD driver) and had seen a good price ... |
Views: 2535 - Replies: 25
| PB12-NSD vs PB12Plus/2 Hi, I was thinking about an upgrade from my PB12-ISD (with an NSD driver) and had seen a good price on a Plus/2 in the UK. Having read on the SVS site a little more about the latest models, I couldn't help but draw comparisons between the latest PB12-NSD and the Plus/2 units. The PB12-NSD has this response curve: Whereas the Plus/2 has this: ![]() For the same 90db output, the NSD appears to have a better extension to 20Hz and below than the Plus/2 has in 20Hz mode. If one is not pushing the SPL levels all that much in a 3000 cuft room, what advantages does the Plus/2 have over the NSD? | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #2 | ||||
| Re: PB12-NSD vs PB12Plus/2 Headroom, headroom, headroom! The Plus/2 will play much louder than any single NSD enclosure, and sound better doing it. In a 3000 cubic foot room the Plus/2 is an excellent match -- grab it! Those SVS graphs are just to give you a general idea of the shape of the frequency response curve -- there used to be a note below each graph saying this. | ||||
| | #3 | ||||
| Re: PB12-NSD vs PB12Plus/2 Hi Malice, The PB12nsd is tuned a bit under 20hz...so it will dig a little deeper than the Plus/2 in 20hz mode. The plus/2 will have a big advantage in output capabilities of course. But if you never/rarely push the PB12nsd very hard...the benefits of that could be debatable.. ![]() Does the room have any large openings to other areas of the home? Also, have you calibrated the system with a meter? If so, how close to reference level do you push action oriented DVDs (with your loudest listening levels)? Tom V. SVS | ||||
| | #4 | ||||
| Re: PB12-NSD vs PB12Plus/2 Hi Tom, Good to hear from you after such a busy period in Vegas! The room is totally closed. I calibrated the "old" ISD driver and BFD'd it. Here's the result(s). I use the flatest curve (filter #1) 99% of the time. ![]() This was calibrated to my Denon's internal test tones which are 75db not 85db. Sub's amp is about 10 o'clock. As I get some grief from she who must be obeyed, I occasionally will listen at -2db, but mostly -6 to -10db. Perhaps a Plus/2 with 12.3 drivers may be a bit of an overkill for my needs? Bob EDIT However, someone did say once upon a time that "640k should be enough for anybody."! Perhaps you can never have too much sub capacity! | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name Last edited by Malice; 01-16-07 at 03:40 PM.. | ||||
| | #5 | ||||
| Re: PB12-NSD vs PB12Plus/2 Hi Malice, If you are pushing things that close to reference level occasionally (2-6dB below reference)...the Plus/2 will offer a more natural, dynamic presentation on the "bassiest" DVDs.. With all speakers set to small, those master volume levels can require the subwoofer to produce peaks of 115-121dB. In your room size, that will be pushing the PB12nsd right to its limits occasionally. I don't know if I would expect a BIG "in your face" type of improvement in the overall bass performance...but at your loudest listening levels...with the bassiest DVDs...it will be audible imo.Tom V. SVS | ||||
| | #6 | |||||
| Re: PB12-NSD vs PB12Plus/2 Quote:
Oh decisions, decisions! Bob EDIT Perhaps just a PB12+ so I can go low than what I can do at the moment! | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name Last edited by Malice; 01-17-07 at 08:26 AM.. | |||||
| | #7 | ||||
| Re: PB12-NSD vs PB12Plus/2 I wouldn't upgrade from the PB12nsd to the PB12plus. The PB12plus will extend a LITTLE lower, and have the ability to play a LITTLE louder(in 16hz)...but the differences are hardly what I would call significant. Hmmm, now that I'm re-reading the thread...do you have the older PB12isd (down firing with base plate) or the newer PB12nsd? Tom V. SVS | ||||
| | #8 | ||||
| Re: PB12-NSD vs PB12Plus/2 Correct: "OLD" ISD design, down firing with the newer NSD driver. Perhaps my opening post comparing the graphs of the newer front firing PB12-NSD and the Pus/2 was a bit of a red herring for my subsequent questions! | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name Last edited by Malice; 01-17-07 at 11:43 AM.. | ||||
| | #9 | ||||
| Re: PB12-NSD vs PB12Plus/2 Yes, that is a little different.. ![]() The PB12isd is a solid performer no doubt---but the new PB12nsd does have the performance advantage(particularly <25hz). The PB12plus would be a noticable improvement over the PB12isd...but I still think you'll be putting yourself in a position to want to upgrade again before long. Moving up to the Plus/2...or waiting for the new PB13Ultra would take care of that risk.. ![]() Tom V. SVS | ||||
| | #10 | ||||
| Re: PB12-NSD vs PB12Plus/2 PB13 Ultra? ![]() | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #11 | ||||
| Re: PB12-NSD vs PB12Plus/2 Me too. Will the PC Ultra tubes be available over here Malace, why not pop down to AV Sales and have a listen at the "New" PB12nsd compared to the Plus2 or wait until the Ultra is about and have a listen to all 3 When i got a demo of the two of them, it was like night and day during FOTP crash scene ![]() | ||||
| | #12 | ||||
| Re: PB12-NSD vs PB12Plus/2 As I live near Blackpool, "popping" down to AV-Sales is not a simple matter! I'd love to audition the Plus/2 but there are two chances of that happening: (1) Fat (2) Slim When you say like night and day, in what respect compared to what? I am sorely tempted by the last of the specials on the Plus/2, but SWMBO hates, yes hates, the sub I have. So to get a "better" one could be grounds for divorce! Bob | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #13 | ||||
| Re: PB12-NSD vs PB12Plus/2 The Plus 2 just seemed to have more presence and authority in the room compared to the NSD. It just felt a more refined sound which outshone my 20-39PC+ which i am used to. It is HUGE compared to the NDS though. I could always pop my tube in the car next time we are up at the pleasure beach, but i don't think ya missus would like my dustbin in your living room for a trial / demo ![]() Toshiba HD-XE1, Playstation 3 (60GB) , Marantz CD52MkII, Sky HD, PS Audio UPC-200HB Audiolab 8000AP, Cinepro 3k6, Kef Reference 3.2, XQ2C (Bridged) , TDM-34DS, SVS PC13-Ultra & AS-EQ1 Panasonic TH50PZ80 & PT-AE3000E, 92" Harkness Hall Tab-Tensioned screen | ||||
| | #14 | ||||
| Re: PB12-NSD vs PB12Plus/2 I've never heard a 20-39PC+ but so many have raved about in blighty land that the Plus/2 must be a very special sub. How big was the demo room? | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #15 | ||||
| Re: PB12-NSD vs PB12Plus/2 IIRC it was probably around 20ft by 15ft. I might be wrong though. Toshiba HD-XE1, Playstation 3 (60GB) , Marantz CD52MkII, Sky HD, PS Audio UPC-200HB Audiolab 8000AP, Cinepro 3k6, Kef Reference 3.2, XQ2C (Bridged) , TDM-34DS, SVS PC13-Ultra & AS-EQ1 Panasonic TH50PZ80 & PT-AE3000E, 92" Harkness Hall Tab-Tensioned screen | ||||
| | #16 | ||||
| Re: PB12-NSD vs PB12Plus/2 Mmmm. about my size. I'm about 21 x 17. ![]() | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #17 | ||||
| Re: PB12-NSD vs PB12Plus/2 To see relative size I thought I'd draw to scale my existing PB12-ISD size to the new front firing PB12-NSD and the PB12-Plus/2. ![]() | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #18 | ||||
| Re: PB12-NSD vs PB12Plus/2 Looks like you are trying to talk yourself into an upgrade there Why not buy one for the missus, stick a nice cloth over it with some flowers on, and she'll never know the difference ![]() Toshiba HD-XE1, Playstation 3 (60GB) , Marantz CD52MkII, Sky HD, PS Audio UPC-200HB Audiolab 8000AP, Cinepro 3k6, Kef Reference 3.2, XQ2C (Bridged) , TDM-34DS, SVS PC13-Ultra & AS-EQ1 Panasonic TH50PZ80 & PT-AE3000E, 92" Harkness Hall Tab-Tensioned screen | ||||
| | #19 | ||||
| Re: PB12-NSD vs PB12Plus/2 That's what my son was telling me this morning as I was taking him to rugby! | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #20 | ||||
| Re: PB12-NSD vs PB12Plus/2 nice job, Malice. if can add PB10-NSD, it's even better. proud to be first SVS user in TW! and so proud to be first TW user with 2 SVSes! now TW first Onkyo 905 user! ![]() threads http://www.hometheatershack.com/foru...s-user-tw.html http://www.hometheatershack.com/foru...html#post32842 http://www.hometheatershack.com/foru...html#post47160 http://photo.pchome.com.tw/lienly | ||||
| | #21 | ||||
| Re: PB12-NSD vs PB12Plus/2 | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #22 | ||||
| Re: PB12-NSD vs PB12Plus/2 tks, Malice. what's that little circle? I guess big one is 12+ driver on SB12+. proud to be first SVS user in TW! and so proud to be first TW user with 2 SVSes! now TW first Onkyo 905 user! ![]() threads http://www.hometheatershack.com/foru...s-user-tw.html http://www.hometheatershack.com/foru...html#post32842 http://www.hometheatershack.com/foru...html#post47160 http://photo.pchome.com.tw/lienly | ||||
| | #23 | ||||
| Re: PB12-NSD vs PB12Plus/2 The white circles represent the driver and the port on the new PB12-NSD. It just happens the driver also appears to be a part of the the SB12 box! | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #24 | ||||
| Re: PB12-NSD vs PB12Plus/2 It might be worth trying a cylinder on your wife. Not literally. My wife would divorce me if I sold her 16-46PCI! You can never tell with women. ![]() | ||||
| | #25 | ||||
| Re: PB12-NSD vs PB12Plus/2 Mine just wants to chop my 12" er out of her life!! ![]() | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
