| SVSound subwoofer in a TV rackDiscuss subwoofer in a TV rack in the Manufactured Speakers and Subwoofers forum; subwoofer in a TV rack is it ok to put a subwoofer (thinking SVS SB12) in the tv rack?
where the red box is in ... |
Views: 748 - Replies: 6
| subwoofer in a TV rack is it ok to put a subwoofer (thinking SVS SB12) in the tv rack? where the red box is in the pic ![]() clickable thumbnail assuming there are no other feasible locations the space the speakers are occupying are only 12" width each side (SB12 is 13.5" wide) and I don't want to place the TV off center Last edited by mike c; 03-29-07 at 01:18 AM.. | ||||
| | #2 | ||||
| Re: subwoofer in a TV rack here's a good artical as to why you should'nt or the measures to take when you do http://www.audioholics.com/tweaks/sp...-installations you can't put it behind the tall fan, if you moved the cabinet over? Last edited by DrPainMD; 03-29-07 at 08:08 AM.. | ||||
| | #3 | ||||
| Re: subwoofer in a TV rack thanks for the link, didn't know it existed at AH. the cabinet is centered to the bed (just like the TV is centered to everything) moving it will create an aesthetic imbalance. it's just that I saw a pic of someone's SB12 plus in a TV rack | ||||
| | #4 | ||||
| Re: subwoofer in a TV rack It's a very small, sealed, front-firing subwoofer, so a few of the points Ray made in his excellent article really don't apply to this particular situation. You don't have much to lose - go ahead and try it there and see if you get any rattles or vibration related equipment problems, etc. If it doesn't go well, you can always remove it and try another location. Ed Mullen Product Development Manager / Customer Service Director SV Sound, LLC www.svsound.com sales@svsound.com techsupport@svsound.com "What We Do In Life, Echoes In Eternity" | ||||
| | #5 | |||||
| Re: subwoofer in a TV rack Quote:
most of the experts say that the subwoofer has to be in a corner to get a better response, but if you want you can try ..... and if doesn't work, you can always look for a better place By the way, Where do you have it now???? | |||||
| | #6 | ||||
| Re: subwoofer in a TV rack the tv rack to the rear wall is about 6" the tv rack to the right wall (where the fan is) is about 11-12" the subwoofer right now is in the extreme left (to the left of the audio rack) - and it sounds boomy. pending the arrival of my sms-1 (no PC in that room for REW) ... I can't really find out the best place yet. but aside from sub location, I thought it'd be fun to have a left and right subwoofer. I'd also get the benefit of full range lefts and rights either by using the "pure direct" mode on the receiver, or using an integrated amp | ||||
| | #7 | |||||
I enjoy watching movies, and I'm sure I will enjoy it more when I calibrate all the system.If your sub is 13.5" it won't make a big difference if you place it on the left side, you said is about 11 - 12"; but if you're happy where you have it now ... I say to leave it there, and if you're planning to have two I think you have enough space to fit them. Good Luck!!! ![]() | |||||
