Noob here on HTS.
I previously owned the SVS PB10-NSD after searching for a sub that would work well for both HT and music. The much larger SVS subs simply do not fit well in my room (nor my wife’s approval), and ported subs, especially the large ones do not do as well for music. After reading that someone had replaced 2 REL Stratus subs for a PB10, I pulled the trigger on one and have been very happy since. I always wondered what I was missing in not being able to own an Ultra however, and it was with great joy that I found out SVS was finally releasing the SB13-Ultra!:sn:
My Ultra finally arrived on the 16th (2 weeks later than you fortunate Americans), and I am now a very happy camper! :T
I just posted this short review on the SVS site so I thought I'd start this thread for the other SB13-Ultra owners out there:
The build quality of the SB13-Ultra is outstanding! Looks great in the Black Oak finish and is heavier than this relatively compact box looks.
I still haven’t watched a full bass-quality movie yet with my new SB13-Ultra nor have I had the chance to run REW. So far I’ve watched scenes of a few movie clips that I’m familiar with (War of the Worlds, Master & Commander, and Ironman 2) to do a quick evaluation of its abilities with just a quick set-up.
On this material, the extension, headroom, and clarity are amazing! Though I know the PB13-Ultra has more output down low, I seriously can’t say I would need more than the single SB13-Ultra already provides. There are fine details heard in some bass sections and sound effects that I don’t remember hearing before being presented with great definition!
Music has always been very important to me as well and is one reason that I’ve been waiting for a SB version of the Ultra. Ported subs, especially large ones, tend to do less well with music.
This is the most articulate sub I’ve ever had the pleasure to listen to! in terms of musicality, the SB13-Ultra is absolutely wonderful. On jazz, you can actually hear the sounds of a double bass player’s fingers pluck the strings, and the nuances in the way the notes are played are easily heard. Playing bass heavy music like “Woofer Cooker” which has serious amounts of deep bass, the SB Ultra more than stands up to the task. This sub is an out-standing subwoofer for music! I had a fellow audiophile over the other day to listen- he has a set of high-end Tetra 505 speakers and is now thinking of adding a SB13-Ultra to his system. The ultra low end bass, quickness, out-put, definition and pure musicality really blew him away.
The only thing I would suggest is that SVS throw in a small mirror as this would make it much easier to set the dial and make the adjustments after it’s set in place. Even better, maybe make a way to reverse the display to use with the small hand-held mirror, however this is minor as it’s still easily read. Would probably only require a small change in the display programming to accomplish.
I have no reservations recommending the SB13-Ultra for HT, and even more importantly, for music. This is a truly superb sub for both audiophiles and Home Theatre buffs.
I’m looking forward to seeing how it does after I tweak it a bit more using REW and make some adjustments with its dual band Parametric EQ.
