I want to buy the SVS PB-13 Ultra but since I know that my pioneer speakers wont do it, I need the speakers relatively small, the sit next to my 27'' iMac because it looks ugly if the speakers a big next to the screen.
Are there any speaker out there within the €250/$250 Bookshelves, that perform well.
Still too big? In my opinion matching something the size of a computer speaker with a PB-13 Ultra does not make sense. The Corsair speakers are the size you want, and in your price range, so why not buy those?
You are going to be running into issues blending anything that small with an Ultra. As soon as the volume increases, the speakers are going to start compressing and the Ultra won't even be trying. It kind of limits how much the Ultra is adding to the system.
In you price range, and close to the size, my best suggestion would be something like the AudioEngine A5 (or A5+ used) or P4's. Still looking at a small speaker, maybe a used pair of Paradigm Millenia 1's, or save up a bit longer and get Paradigm Studio 10's.
Is there room to fit a larger speaker in your set up, and it is just aesthetics you are concerned about, or are you actually severely size constrained in your room?
I'm convinced to use slightly bigger speakers, perhaps the Klipsch RB 41 II? or something similar. Also is an High sensitivity a good thing, or does that drain the sound quality?
And there is also the fact that my AVC-A1SE is only 2x170 @8Ohm.
My room is 3m W 5m L 3m H, so I don't have a lot of space and aesthetics are a important fact its like, performance 9 design 7.
I just watched the newest batman with my PB13 Ultra. You just can't replace how good this sub is. My only problem is that my whole house shakes and somehow I am trying to convince my wife that we need another Ultra sub.
Good idea, my next purchase should be a second sub.
Related Threads
742.3K posts
170.9K members
Since 2006
