Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
money well spent??
Discuss money well spent?? in the Manufactured Speakers and Subwoofers forum; money well spent?? Ok, I need some help, I'm ready to by a SVS sub, my choices are 25-31PC+ or SB12+. The cylinder ...
Views: 1159 - Replies: 20
Old 10-01-07, 06:19 PM   #1
Alias: OLED
organicled's Avatar
Loc: North Huntingdo pa, 15642
User: #10781
Since: Aug 2007
  organicled is offline
money well spent??
Ok, I need some help, I'm ready to by a SVS sub, my choices are 25-31PC+ or SB12+. The cylinder is about $125 more, and what I’ve found regarding specs they are about the same. Will the 25-31 give me the big difference at the better low endor is it similar to the SB12? I plan to place the 25-31 behind my TV cabinet (cabinet is 8-10' off side walls) in the corner, but it will be almost against the walls, will this be a problem? I like the fact that the SB12 will be out in the open so I can show off this money clip My room is 13x18x8 and other speakers are DefTech SM350/PC2000/PM1000's. My budget could stretch to fit the 25-31, but that would put in the hole and I have the cash now for the SB12. Since I don't plan to upgrade again for a long time I want to make sure I get it right the first time. Listening habits are 25/75 music to movies, but that is sliding more too 50/50 since I just got the DefTechs.
Old 10-01-07, 11:06 PM   #2
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
Re: money well spent??
the pc plus will demolish the sb12 in SPL ... even SVS will tell you that if you can fit the the bigger ported subs, to get those instead of the sb12 which is tailored for those who have space restrictions or a big % of music usage.
Old 10-03-07, 07:24 PM   #3
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
I agree... if I had the choice between those two I would choose the PC+ and never look back. You will be thankful on movies with good low bass.
Old 10-04-07, 12:01 PM   #4
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
  Mitch G is offline
FWIW, I have the 25-31 PC+ and love it. I have it tuned to 20Hz using one of the provided port plugs and then equalized with a BFD. The cylinder is still rather large. Mine's behind my TV, so it's not a problem for me. So, you may want to get some poster board and do some level of mock-ups for both subs and see how they "fit" in your room.
Also, if not in a terrible hurry you may want to watch for b-stock and save - I think it's generally a $50 discount for b-stock, iirc. I bought mine b-stock and you would never know. I'm pretty sure that most of the time the b-stocks are returned because the buyer was surprised by the sub's size. If you are familiar with perl, I can send you a little hack I wrote that checks the b-stock page and will tell you if it sees what you are looking for.
Mitch
Old 10-04-07, 01:09 PM   #5
Alias: OLED
organicled's Avatar
User: #10781
Since: Aug 2007
Mitch - yes, please send, thank you. I have also posed this question to SVS and am waiting for a reply. i think i'm going to try doing a mockup of the clyinder, the WAF has full veto power when it comes to this sub. I showed her a photo of each sub and she want to know if i can paint them to match the walls better She is kind of board with the SB12 but the clyinder is going to take much more work even if it is behind the TV.
Old 10-04-07, 11:26 PM   #6
Alias: Mitch
User: #2469
Since: Sep 2006
  Mitch G is offline
The cylinder is wrapped in a velvet cloth type of thing. So, painting it would definitely be trickier since you would have to remove the outer skin and then I don't know what.
I bet it would basically be invisible behind a 60" TV, though.
Mitch
Old 10-06-07, 02:54 AM   #7
Silver Supporter
Alias: Geoff
Loc: Columbia, MO
User: #1654
  Geoff Gunnell is offline
At a guess the sub position you've shown by the entry to the dining room won't work. The sub has too little wall reenforcement and is next to one of the openings out of the volume you want to power.
Behind the TV is the best option to blend with your main speakers easily, but behind your couch would give you the strongest bass. Remember that the cylinder can be laid on it's side in either location.
If for some reason the cylinder is vetoed in all these positions, and you end up using the SB12+, the behind the couch in the corner placement would really help couple the bass output to your listening position.
Old 10-06-07, 09:50 AM   #8
Alias: Bob
User: #9172
Since: May 2007
  tc-60guy is offline
Hello Organicled, Although I'm a delighted SB-12 owner I would lean toward the bigger sub if I had the room. I live in a studio apartment in NY so size does matter. I'm using my sub mostly for music so bone crushing bass is not high on my list of priorities. Although the SB-12 hangs in there pretty well for vidio use It's working hard and sounds like it! For mixed use in a larger room the bigger sub is the way to go. Hope this helps.
Old 10-06-07, 10:24 AM   #9
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
  E-A-G-L-E-S is offline
I have the 20-39PCi and it really kicks your butt. The + would be even better.
I also agree with placing it behind the t.v. -OR- behind the bend of the "L" couch in that corner.
Old 10-06-07, 10:37 AM   #10
Alias: Bill
Loc: Tampa, Florida
User: #10903
Since: Aug 2007
  bill-merritt is offline
SVS has a b-stock PC-30-29Plus! Today! Good for anyone looking!
Old 10-07-07, 11:54 AM   #11
Alias: OLED
organicled's Avatar
User: #10781
Since: Aug 2007
Thanks for all the input, i never thought about laying the clyinder down, that might just work. i am saving up extra cash to get both subs to do a side-by-side comparison and just return the other. i know it may cost me about an extra $75 if i need to send the cylinder back but at least i will know how both sound in that room and a won't have regrets. Humm... on its side.
Old 10-07-07, 07:02 PM   #12
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
where is north huntington? i'm in allentown if it's close enough to drive for a listen....
Old 10-08-07, 01:21 AM   #13
Silver Supporter
Alias: Geoff
Loc: Columbia, MO
User: #1654
organicled wrote: View Post
. . . Humm... on its side.
This is not a new idea, BTW -- the first horizontal cylinders I remember were the Bazooka brand car subs in the mid '80s.
The placement of a horizontal cylinder 'behind the couch' has a couple unique characteristics:
It's the most effective way to stretch your sub dollar when you have a large space and a small budget.
It even has a name: the Horizontal Cannon!
Old 10-08-07, 08:53 AM   #14
Alias: OLED
organicled's Avatar
User: #10781
Since: Aug 2007
E-A-G-L-E-S wrote: View Post
25 miles east of Pittsburgh, Allentown may be a far drive, but I great appreciate the offer. Wife just informed me that she would not be happy if she saw a sub in front of the speakers, if it was behind the TV she would like that better. I took this as a law not just her recommendation, so clyinder it is. Looking at getting an older PC-Ultra, will an older (3 year)Ultra be a good choice? I know it is on the far end of the subs i was looking at but, well, just may happen.
Old 10-08-07, 09:45 AM   #15
Silver Supporter
Alias: Geoff
Loc: Columbia, MO
User: #1654
A used PC-Ultra would be an excellent choice for you IMO, giving you much needed output and very good sound quality.
Old 10-19-07, 06:35 PM   #16
Alias: OLED
organicled's Avatar
User: #10781
Since: Aug 2007
Update :
I bought a SVS PC20-39+, it should be here by Friday, now what am i suppose to do?
Just joking
But i do have a quick question, I currently have my crossover set to 80 hertz for my Def Tech SM350/PC20/PM speakers, my receiver can not do more than one crossover, would anyone know if I need to change the crossover higher or lower or is that something i should do after calibrating?
Old 10-20-07, 12:11 AM   #17
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
It is something of personal taste. The single crossover is all that many receivers have, it is the general point between mains and sub.
80Hz is too high for many as it lets in some 80+ signals and that is more of a midbass. Some like 80Hx to get the punch.
I set mine to 80Hz for music and 60Hz for movies.
Old 10-20-07, 08:31 AM   #18
Alias: OLED
organicled's Avatar
User: #10781
Since: Aug 2007
What receivers have the ability to do multi able crossovers at a reasonable price? I've looked a specs and I can't tell if they can do more than one or not.
Old 10-20-07, 10:42 AM   #19
Silver Supporter
Alias: Geoff
Loc: Columbia, MO
User: #1654
You might be interested in reading at least part of the following article:
http://www.hometheaterhifi.com/volum...rs-9-2002.html
To skip to the part that addresses your question, scroll down until you see a dark bold header line:
"Mixing high and low frequency crossovers in a multi-channel set up"
The bottom line is you are better off sticking with a single xo frequency.
If you want to move that xo down to the 50-60 Hz range, you should invest in surrounds that will play that low rather than a receiver that tries to accomodate them.
Old 11-03-07, 10:08 AM   #20
Alias: Jeff
Captain Crunch's Avatar
Loc: Greenville, SC
User: #7934
Since: Apr 2007
  Captain Crunch is offline
If your looking for something at a decent price Id look at the Onkyo 605 that's great bang for buck unit.
U can get it for $349 here...ONKYO .605 ......never used this dealer though ......you may want to check pricegrabber.
Old 11-03-07, 11:41 AM   #21
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
  Scuba Diver is offline
That was a good article thanks for posting.
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
