SVS PB1000 and SB1000 Subwoofer Review Discussion Thread - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #71 of 82 Old 04-23-16, 02:28 PM
Re: SVS PB1000 and SB1000 Subwoofer Review Discussion Thread
I am looking to upgrade from my current subwoofer which is a Polk DSW 550wi. It would pair up with a Yamaha YSP-5600 soundbar.
The room is 14x21 with 10ft ceilings. Usage is pretty much 70% movies and 30% music. We listen at medium to loud levels.
I have been looking at the SB-1000 because of size and WAF. My budget is around $700.00 but could go a bit higher is need be, so the SB-1000 is well within my budget. SVS told me the SB-1000 should be able to handle a room of this size with no problem but would just not play as loud through the frequency range.
Anyone have experience with the SB-1000 in a room of this size?
I have been looking at the SVS and Martin Logan Dynamo 700w and if I go with the SVS would be also purchasing their
wireless kit.
Yamaha YSP-5600
Polk DSW PRO 550wi Subwoofer
Sony BDPS590 BluRay
Sharp LC-60C8470U TV
tasdisr is offline
post #72 of 82 Old 04-24-16, 09:10 AM Thread Starter
HTS Moderator
Reviewer
theJman's Avatar
Jim
tasdisr wrote: View Post
wireless kit.
My review was done in a room about 1200 ft^3 smaller than yours, and the SB1000 was just enough for the amount of space I have. Frankly, I don't see the SB1000 being able to provide sufficient output and depth for movie watching in the 2940 ft^3 you have. For music perhaps, but not movies. If WAF prevents you from getting something more appropriate - like the PB2000 - you might want to consider the SB2000 instead. That would fare better in your room and fits within the budget.
-Jim
theJman is online now
post #73 of 82 Old 04-24-16, 10:24 AM
theJman wrote: View Post
Thanks for the input. I will have to take a look at the SB2000 and PB2000, even though I don't think the PB2000 will pass the WAF.
When I contacted SVS they said the SB1000 should be able to handle a room that size. That is why I like to ask forum members to get their feedback on real world applications.
tasdisr is offline
post #74 of 82 Old 04-24-16, 12:52 PM
willis7469's Avatar
I Agee with Jim here. A pb2k is the minimum sub I'd purchase for that much space. If you're on concrete, it's that much worse(not sure if you are). I had an sb2k and it's fantastic and small. I think it's not enough for 3000cuft either. As far as WAF goes, don't forget that it's your space too. I remind myself that periodically, however we have 7.3 in our living room so I've use up a lot of WAF.
Sent from my iPhone using Tapatalk
willis7469 is online now
post #75 of 82 Old 04-24-16, 01:13 PM
willis7469 wrote: View Post
Thanks, I am not on concrete. Wood floors and full basement under that. I have also used up a lot of WAF but we will see what happens.
I may be able to swing the SB-2000, at least it is a little narrower and not as high as my current sub.
Yamaha YSP-5600
Sony BDPS590 BluRay
tasdisr is offline
post #76 of 82 Old 04-24-16, 03:19 PM
I agree. If your budget is $700, the SB-2000 would be a better option. If you can stretch your budget a bit (and maintain WAF), you might want to try dual SB-1000s.
gordog is offline
post #77 of 82 Old 04-24-16, 03:50 PM
gordog wrote: View Post
I can stretch the budget but not the WAF.
b bos37 likes this.
tasdisr is offline
post #78 of 82 Old 09-21-16, 09:10 PM
Hi guys. I can new to this forum and I wanted to ask some questions about the PB1000. My room is about 1100 cubic feet with a carpeted floor. I like games, movies, and music equally. I like Metal/rock/dubstep/EDM. Would that sub be enough or should I increase my budget? I read Jman's review and it seems the PB1000 seems good to me. Thanks.
scorpion_pepper is offline
post #79 of 82 Old 09-22-16, 07:15 AM Thread Starter
HTS Moderator
Reviewer
theJman's Avatar
Jim
If your room is sealed, so 1100 ft^3 is the entire space, then the PB-1000 would have no problem with that. The room I used for my review is about 50% larger than yours, and it was just fine. If you really like to push things the PB-2000 might be more to your liking, but if your budget doesn't allow that I think you would be pleased with the PB-1000.
scorpion_pepper likes this.
-Jim
post #80 of 82 Old 09-22-16, 07:25 AM
Do you think the PB2000 to be worth $800? I assume you would consider the Rythmik LV12R a much better buy for $590? The PB1000, PB2000, and Rythmik get lots of positive reviews though. Thanks!
discussion , pb1000 , review , sb1000 , subwoofer , svs , thread
