Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
SVSound PB13-Ultra VS Velodyne DD-15
Discuss SVSound PB13-Ultra VS Velodyne DD-15 in the Manufactured Speakers and Subwoofers forum; SVSound PB13-Ultra VS Velodyne DD-15 Any Ultra owners compared the Velodyne DD series?...
Views: 2385 - Replies: 16
Old 10-22-07, 08:56 AM   #1
nickh
Inactive
Alias:
User: #
Posts: n/a
Old 10-22-07, 01:11 PM   #2
Alias: mojomike
Loc: South Florida
User: #6557
  mojomike is offline
Re: SVSound PB13-Ultra VS Velodyne DD-15
There have been a couple of direct comparisons done. One was by Craigsub on the sub forum on AVS. Another was by the group at a Toronto GTG on the SVS forum on the Spot forums.
Edit: Correction: The comparisons were between the 13Ultra and the DD18, not the DD15.
Old 10-22-07, 09:12 PM   #3
Alias: chengbin
User: #12625
Since: Oct 2007
  chengbin is offline
Basically PB13 beats any DD series subwoofer in any category you can think of (except size)
Old 10-22-07, 09:24 PM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
chengbin wrote: View Post
Not exactly true. The DD15 and especially the DD18 has more upper bass output (above 45-50 Hz) than the PB13-Ultra.
Old 10-22-07, 09:42 PM   #5
Alias: chengbin
User: #12625
Since: Oct 2007
  chengbin is offline
Oh, I'm not aware of that. But except that, the PB13 beats any DD subwoofer right?
Old 10-22-07, 10:02 PM   #6
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Well I wouldn't necessarily use a word 'beat', but yes, the PB13-Ultra has more deep bass output due to being ported. Both of them (DD18 and Ultra) are great subwoofers. One of the best commercial subwoofers there is. The built-in EQ that the DD18 has is pretty handy.
Old 10-23-07, 07:15 PM   #7
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
if you mean "beat" in output ... yes
objective tests prove that.
subjectively, have you heard both?
Old 10-23-07, 07:19 PM   #8
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
mike c wrote: View Post
It depends of the frequency. Up higher the DD18 is stronger, down low the PB13-Ultra has more output. Both have lots of output at all frequencies though.
Old 10-23-07, 07:31 PM   #9
Alias: chengbin
User: #12625
Since: Oct 2007
  chengbin is offline
Based on Craig Chase's comparison, the PB13 is better than the DD-18 in movies and music. So as a comparison from the user pbc with his f113, PB13, DD-18, and servo-15 v2.
Old 10-23-07, 09:09 PM   #10
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
while I put a lot of stock in Craig's ranking ... it's also very subjective.
for example, I have the DD18 and Axiom EP500, the DD18 is higher on the list and yet for HT, the Axiom seems better, but for jazz/classical music, the DD18 is indeed better ... but then my dual CHT-15R/DLS-5000R's are better for r&b music.
if you see how much my subjective taste swing the ranking ... you'll learn to take everything you read on the web with a grain of salt ... especially mine.
Old 10-23-07, 09:12 PM   #11
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
Ilkka wrote: View Post
i'm thinking max SPL ...
but in specific frequencies, the servo might give the DD some advantage in the upper bass.
Old 10-23-07, 09:18 PM   #12
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Max SPL using what kind of input signal? It's always related to frequency.
Actually it's not the servo but the larger cone and higher amp power instead.
Old 10-23-07, 09:24 PM   #13
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
doesn't the servo/DSP cut off the low end in high drive levels to be able to produce the high bass?
Old 10-23-07, 09:31 PM   #14
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
The servo itself doesn't do any limiting, it only ensures that the output follows the input signal as accurately as possible. Other circuits (quite possibly DSP) do the limiting.
But actually I meant the single frequency situation, not what happens during wide band content. In both cases, the DD18 has more upper bass output/headroom.
Old 10-23-07, 10:21 PM   #15
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
that's nice to hear.
Old 10-24-07, 03:36 PM   #16
Alias: Ron
Loc: San Jose, CA
User: #12483
Since: Oct 2007
  Ron Temple is offline
I had a chance to play with a DD15 for about a month awhile back. It's a very impressive sub, especially for music. I also had a 20-39+ in the house at the same time. The DD went back, though I could have kept it. The SVS outperformed it for HT and my system wasn't up to the caliber of the Velo for music. Well times have changed and my system now could handle the Velo, but I swapped out a pair of SVS Pluses for the PBU13. Subjectively, I appreciate the new Ultra even more than the DD for music and HT is awesome...textured bass, extremely tight, as well as, deep. The built in software and calibration tools on the DD are wonderful, though no bargain. The PEQ combined with room compensation on the U13 is pretty useful in getting relatively flat without treatments or EQ and is a bargain.
Old 11-06-07, 03:59 PM   #17
kioko12
Inactive
Alias:
User: #
Posts: n/a
What is the price of a new DD18/15? I'm pretty sure that you could purchase multiple PB-13 Ultras for the cost of a single Velodyne...
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
