Pb10 turn off thumps ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
Discuss Pb10 turn off thumps ? in the Manufactured Speakers and Subwoofers forum; Pb10 turn off thumps ? I very seldom switch the power off on the the back of the sub ,but when I do turn off ...
Old 11-27-07, 12:15 PM   #1 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
jwhite8086 is offline
I very seldom switch the power off on the the back of the sub ,but when I do turn off one of the two Pb10s the other sub makes an awful powering down sound . The sound is like a subsonic rumble thats slowing to a halt and droping to a deep hz that you cant hear then the sub flutters with an awful sound like its bottoming out and stops. This happens when I turn one sub off while the other is on the sub thats on gets effected, but I just tried to make it happen again and it didnt.
Why does this happen?
Old 11-27-07, 12:24 PM   #2 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Re: Pb10 turn off thumps ?
That is a good question, I would submit this to SVS and see what they say. It would help if you can tell us how they are connected, if they are powered by the same wall outlet, etc. Thanks, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 11-27-07, 08:32 PM   #3 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
They are are connected to the HTR5760 sub out monster y adapter and two Monster sub cables both pluged into the same surge protector, "a Walmart Newpoint" the ground and protection lights are both lit. I turned the sub off again after watching a movie and BRRRRRRRRrrrrrrrddd.
Old 11-28-07, 03:47 AM   #4 (Link)
SVSound
Alias: Ed
Loc: Upstate New York
User: #1779
Ed Mullen is offline
Sounds like a flaky amp not muting the output stage when the caps are discharging. Please contact us at tech support to determine warranty coverage and to get the replacement process moving. Thanks!
Ed Mullen
SVS Customer Service
www.svsound.com
sales@svsound.com
techsupport@svsound.com
"What We Do In Life, Echoes In Eternity"
Old 11-28-07, 08:16 PM   #5 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Is there any other way to test the amps to see witch one or both are doing this? I remember both subs doing it the first time I did it on each sub the one that was still on made the sound.
Should they both be pluged in the same outlet on a surge protector?
Is this something I should worry about fixing,
Also the gain knob on one of the subs is about 1/4 different in volume then the other and yesterday one gain knob had static when moved but stoped after i turned it all the way up then down.
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
Similar Threads
Sony 53XBR45 Turn-On Issue garycase2001 Manufacturers Service and Support 2 01-16-08 10:04 PM
Mitsubishi 42" widescreen will not turn on stymee Manufacturers Service and Support 15 11-29-07 04:12 PM
Huge POP when I turn on the 1124P 1984911Porsche BFD Forum 4 10-09-07 10:13 AM
sub hums if I turn on SPL meter subby REW Forum 56 09-13-07 05:13 AM
Turn the screen on! Chrisbee Forum Help | Suggestions 4 02-01-07 08:08 PM
Mach 5 Audio
