Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > SVSound
SVSound
SVS PB-12 plus/2
Discuss SVS PB-12 plus/2 in the Manufactured Speakers and Subwoofers forum; SVS PB-12 plus/2 Phobitos wrote: Hello, A question about the base plate. You just use the default mounting configuration of foam disks, or ...
Views: 4846 - Replies: 26
Old 04-17-07, 09:16 AM   #26
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
  Warpdrv is offline
Re: SVS PB-12 plus/2
Phobitos wrote: View Post
Hello,
A question about the base plate. You just use the default mounting configuration of foam disks, or use the six black round rubber ends that are included in the package of our wonderfull sub?
Thank you
You can use whatever fits better for your situation, I obviously have wood floors, and mine was bouncing around quite a bit... so I ended up cutting some of the Packing Foam the SVS came with, and slit it underneath to try to decouple the sub from the floor, and it worked great.... Bass was much more linear, and lot creating resonance in the flooring as it shakes the dam house so much...
Also it was like a mexican jumping bean, and the foam fixed that quite nicely..
What kind of floor is your sub on...? carpet.. wood, concrete...?
Old 04-17-07, 09:31 AM   #27
New Member
Alias: Fer
Loc: I ain't tellin ya!
User: #952
Since: Jun 2006
  Phobitos is offline
Thank you,
My floor is concrete and the default foam disks seem to do well in order to decouple the sub from the floor. I have the doubt if it would be better with the rubber ends. Perhaps I will try although this sub is a very heavy one
« Home Theater Shack > Manufactured Speakers and Subwoofers > SVSound »
