| SVSound To upgrade or not?Discuss To upgrade or not? in the Manufactured Speakers and Subwoofers forum; To upgrade or not? I have a Klipsch RW12d. It's not the most impressive sub on the market but I think it sounds pretty ... |
| | #1 (Link) | |||
| To upgrade or not? I have a Klipsch RW12d. It's not the most impressive sub on the market but I think it sounds pretty nice in my setup. My other speakers are Klipsch RB81's bookshelves (x4) and a RC62. I plan on moving everything down to a dedicated theater room in about a month or so. The volume is around 1600 ft³ (20x10x7¾). I'm not sure if my Klipsch Sub will fill the room well enough. I know SVS subs will dig deeper and are probably the best value out there. What sub would you recommend given a budget of $1000 or less? Less being more acceptable to my wife. Also what would the benefit of your recommendation yield over my current sub? | |||
| | #3 (Link) | |||
| Re: To upgrade or not? Wow...that's more than 10Hz lower and a bit louder. I think SVS's bottom shelf sub beats the RW12d in extension. Is that graph with the parametric EQ on? It has a very flat response. Do you know how accurate (musical) their subs are? | |||
| | #5 (Link) | |||
| Re: To upgrade or not? I'd recommend the PB12-Plus also. It is one of the cleanest you'll find, even cleaner than the PB12 Plus/2 I just picked up. The Plus/2 has two drivers and a bit more headroom and is on clearance now for 1099 plus shipping. If that really breaks the budget there's also the PB12 NSD/2 which is the same cabinet with different drivers and a little less power, but is still considered one of the best for I believe for $799 Plus shipping. You can't really go wrong with any of these subs, it's just a matter of determining what will work best for you. Give SVSound a call. They'll be happy to discuss your requirements and won't try to oversell you. They were very helpful in helping me to determine my needs, and I couldn't be happier with my SVS!!! | |||
| | #6 (Link) | |||
| Re: To upgrade or not? I just installed dual PB12+ subs today in my media room.. they replaced a couple of much older, but high end subs. It will take some time for the speakers to burn in, but they already sound awesome. Chris | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Need an upgrade | tweeksound | Video Displays and Processors | 13 | 10-28-07 12:18 PM |
| Would like to upgrade my display | Blaser | Video Displays and Processors | 11 | 09-15-07 09:19 AM |
| Considering the 2.35:1 anamorphic upgrade? | rwood01 | Home Theater Projectors | 24 | 04-12-07 06:52 PM |
| upgrade | jokers10 | SoundSplinter | 1 | 10-11-06 10:48 AM |
| Looking to upgrade | Joshua | Home Theater Equipment | 3 | 05-18-06 11:16 AM |
