| SVSound two PC-Plus 20-39 vs PC13-Ultra.Discuss two PC-Plus 20-39 vs PC13-Ultra. in the Manufactured Speakers and Subwoofers forum; two PC-Plus 20-39 vs PC13-Ultra. My first post.
I allready have a PB12-Plus/2 (12.2 drivers).
Because off a serieus placement problem, i'm thinking to buy ... |
| | #1 (Link) | |||
| two PC-Plus 20-39 vs PC13-Ultra. My first post. I allready have a PB12-Plus/2 (12.2 drivers). Because off a serieus placement problem, i'm thinking to buy a single PC-ultra or two 20-39 Plus subs. I know de two 20-39 will have more output, but will they go as low as the ultra? Gr. Wim. | |||
| | #2 (Link) | |||
| Re: two PC-Plus 20-39 vs PC13-Ultra. output wise - would only be a small advantage and would depend on what frequencies. go ultra! that way, one day you can buy a second one. http://www.hometheatershack.com/foru...us-12-3-a.html http://www.hometheatershack.com/foru...-tune-new.html Last edited by mike c; 01-17-08 at 06:22 PM. | |||
| | #6 (Link) | |||
| | Re: two PC-Plus 20-39 vs PC13-Ultra. I had one PB12-Plus/2 in the front corner of my very symmetrical room for one night... added the second one the next night in the opposite front corner. There was no difference in response measurements. Because is was symmetrical and both equal distance in each front corner with the listening position centered, the only thing a second sub did was give me more impact and SPL. It was a noticeable difference. The key to getting a second sub to help smooth out your response is to be able to experiment with multiple locations. Once I got to experimenting I began to see how it could help me smooth out my response. I ended up placing my second sub in the rear of the room, about equal distance from the listening position, both in phase... and twala! Since then I've built a sub for the rear and placed the Plus/2 back up front where it was. 2 up front and 1 in the rear. Works beautifully! ![]() | |||
| | #7 (Link) | ||||
| Re: two PC-Plus 20-39 vs PC13-Ultra. Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| SVSound PB13-Ultra / PC-Ultra Giveaway Qualification Thread | Sonnie | SVSound | 44 | 02-14-08 04:36 PM |
| The SVSound PB13-Ultra / PC-Ultra Giveaway | Sonnie | SVSound | 51 | 02-01-08 11:01 PM |
| Pc13 + Pb12-nsd = | alexadams77 | SVSound | 10 | 11-16-07 12:37 PM |
| PB13 vs PC13 Ultra | alexadams77 | SVSound | 11 | 11-14-07 12:57 PM |
