| System Setup and Connection installing ampDiscuss installing amp in the Home Theater | Audio and Video forum; installing amp I have a Denon reciever that has pre out for subs can I hook up amp there then both my ... |
| | #4 (Link) | |||
| Re: installing amp There are 2 ways you can do this, if your reciever has 2 sub outs (many do) then use 1 to amp then amp to sub and the other directly to powered sub. OR If you only have one sub pre out go to Radio Shak and get a RCA splitter (1 male end that splits to 2 female ends) and hook up as above............1 to your amp then go from that amp to passive sub, the other jack you hook up RCA to the Input on powered sub. Then calibrate and enjoy! | |||
| | #5 (Link) | ||||
| Re: installing amp Quote:
| | #6 (Link) | |||
| Re: installing amp Ask if any members are in your area to maybe help for beer and dinner, you need a SPL meter (found at Radio Shak) and test disc's found online there is also trying it by ear, In this example its tricky because I have never done it with more than one sub. Anyway you place sub where you sit and walk around room paying attention to where it sounds best (hopefully its near walls and corners for WAF) and you then place sub where you were standing when it sounded best. (WAF= Wife Acceptance factor). With 2 subs you need to be careful of placement so as to not cancel each other....it can get a bit technical. There are other ways to do this that can be simple or complicated with increased knowledge and financial investment needed so again I hope you can maybe find a close member for some in person help. | |||
| | #7 (Link) | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Installing a 4" precision port? | eyekode | DIY Subwoofers - Sealed and Ported | 5 | 05-02-08 08:05 PM |
| SVS SB12-Plus & PB12-NSD review - Lyd & Bilde (English version) | L-Sound - Jan | SVSound | 4 | 12-16-07 01:41 PM |
| News: Toshiba A2 & A20 prices reduced $100 & web enabled features | bobgpsr | High Definition | HD DVD | Blu-ray | 0 | 06-29-07 12:36 PM |
| Calibration – Cant get a Flat response ? CM-140 & DSP1124 & REW | tapeshc | REW Forum | 8 | 04-10-07 09:52 PM |
| SVS SBS-01 & PB10-NSD review - Lyd & Bilde (English version) | L-Sound - Jan | SVSound | 0 | 03-27-07 01:26 PM |
