| System Setup and Connection How to connect sub to Yamaha V661 w/busted low level input ??Discuss How to connect sub to Yamaha V661 w/busted low level input ?? in the Home Theater | Audio and Video forum; How to connect sub to Yamaha V661 w/busted low level input ?? I believe the Sub/LFE out on my Yamaha RX-V661 has gone bad.
I received a used subwoofer for temporary use ... |
| | #1 (Link) | |||
| How to connect sub to Yamaha V661 w/busted low level input ?? I believe the Sub/LFE out on my Yamaha RX-V661 has gone bad. I received a used subwoofer for temporary use and it would not turn green and play. So I connected my Aiwa's left speaker output to the high level inputs + & - and bingo. So, it has to be my sub out or possibly the sub cable, correct? How can I connect the sub without using the sub out on my receiver? | |||
| | #2 (Link) | |||
| Re: How to connect sub to Yamaha V661 w/busted low level input ?? The only other option (at least to test) is to put your crossover for the main channels to full and hook up your sub to the left pre out (if your sub has a stereo inputs) use both left and right pre outs. Thats the best you can do. In the Yamaha's menu make sure you tell it that there is no sub. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | |||
| | #4 (Link) | |||
| Re: How to connect sub to Yamaha V661 w/busted low level input ?? I felt so stupid I didn't want to respond. After taking yet another look over everything two thoughts came to me: 1. The red light never went green when playing off my Aiwa, so that light just doesn't work correctly, so......... 2. Maybe this sub just stinks? Maybe it just has no beef whatsoever. So I went back into my Speaker Level settings and cranked the SBWR all the way up, then turned the gain on the sub all the way up.......turned on the music and BAM. There is the bass. Though not much. (I had become used to my old eDA5-350) So sorry for wasting your guys' time and thank you for helping. | |||
| | #5 (Link) | |||
| Re: How to connect sub to Yamaha V661 w/busted low level input ?? No problem Matt, remember the only "stupid question" is a question not asked. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| FS: Yamaha RX-V661 | E-A-G-L-E-S | Classifieds - Audio Equipment | 3 | 06-28-08 02:59 PM |
| Defective BFD, or Input Level too low? | vfa727 | BFD Forum | 3 | 02-07-08 01:36 PM |
| Can I run a second sub off my Yamaha RX-V661 7.1 receiver? | E-A-G-L-E-S | Home Theater Components | 3 | 11-17-07 02:29 PM |
| Yamaha RX-V661? | FlashJim | Home Theater Components | 9 | 11-12-07 10:30 AM |
| REW/BFD input level setup on a yamaha r-v661 ? | tdamocles | REW Forum | 5 | 10-23-07 08:14 PM |
