Why should use my receiver's HDMI output? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Why should use my receiver's HDMI output? in the Home Theater | Audio and Video forum; Why should use my receiver's HDMI output? Hello, I realize this is all relatively low end equipment, but I'm new to HT and wanted to start slow. ...
Old 04-21-08, 01:48 AM   #1 (Link)
New Member
Alias: Fred
User: #19859
Since: Apr 2008
nc72922 is offline
Hello,
I realize this is all relatively low end equipment, but I'm new to HT and wanted to start slow. I just bought a Onkyo TXSR605 receiver, 46" Vizio LCD TV, and a Direct TV HD-DVR. Currently, I have the HDMI out from the DVR hooked up directly to the TV, but I'm wondering if I should send it thru the receiver?
Thanks,
Fred
Old 04-21-08, 08:28 AM   #2 (Link)
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Kal Rubinson is offline
Re: Why should use my receiver's HDMI output?
1. Some receivers will offer quality video processing but I do not know if yours does.
2. It permits audio over HDMI and that will allow for the HD codecs that cannot be fed over optical or coax.
3. It is convenient to have one unit do all the input switching.
Your move.
Kal
Old 04-21-08, 09:45 AM   #3 (Link)
New Member
Alias: Fred
User: #19859
Since: Apr 2008
nc72922 is offline
Thanks.
I'll give it a try and see what I get.
Fred
Old 04-22-08, 12:23 AM   #4 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
superchad is offline
I avoid extra signals paths when ever possible so I use HDMI for video direct and Coax for audio, this is why I have held off on Blu Ray as I am waiting for 7.1 internal decoders with multi channel bypass output and it looks like this summer I may get my wish. If you dont have to run wire into something just to go back out of it you will save money and potential signal degration as a straight line is most always best.
Old 04-22-08, 02:00 PM   #5 (Link)
New Member
Alias: Fred
User: #19859
Since: Apr 2008
nc72922 is offline
Well,
I tried connecting the TV to my Onkyo receiver and was not happy with the picture quality, however that may be due to the low-end HDMI cable I had going between the satalite box and the receiver. For now, I think I'll stick with the direct connect to the TV and the optical to the receiver.
Old 04-23-08, 10:22 PM   #6 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
Its not the cable, HDMI doesnt have to cost much to be good if its a normal meter or two in length so I highly doubt its the cable.
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Best advice integrating receiver's "room eq" with BFD Rambo4 Home Audio Acoustics 10 04-22-08 06:51 PM
New Denon receiver: can it output component from HDMI sources? John Simpson Home Theater Components 4 12-30-07 01:37 AM
Using Receiver's EQ jpm11 REW Forum 4 11-14-07 03:44 PM
Box Sub Output vs. IB Sub Output NickTF DIY Subwoofers - Infinite Baffle 15 10-18-07 09:25 PM
HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? geekwithfamily Home Theater, Audio and Video News 2 02-27-07 11:11 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
