Need Help for a Dummy - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Need Help for a Dummy in the Home Theater | Audio and Video forum; Need Help for a Dummy I have a Yamaha YHT-585BL HTiB, which came with the HTR-6050 reciever. I have been unable to get all 5 ...
Old 04-29-08, 05:38 AM   #1 (Link)
New Member
Alias: Mark
User: #16479
Since: Feb 2008
mfk5331 is offline
I have a Yamaha YHT-585BL HTiB, which came with the HTR-6050 reciever. I have been unable to get all 5 speakers to play, and was told I needed a digital connection, which I know nothing about. Right now I have everything hooked up to my HDTV with the audio inputs plugged into the reciever. This means to play XBOX I have to switch the TV to the component setting then switch the reciever to the proper input. I would like to have everything simple so I dont have to use 2+ remotes at hand all the time. Would it be possible to have everything hooked up to my HDTV and have just a cable running to my reciever that would just play any sound that would come from the TV?
I am a complete moron when it comes to home theatre, all I want is my surround sound to sound good and perform to its full potential, which it is not right now (only plays from rear speakers, center and sub). Can somebody explain to me the best setup, how to hook everything up correctly, and what cables I need to get? Again, so a dummy can understand it?
Thanks a bunch.
Old 04-29-08, 08:51 AM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is online now
Re: Need Help for a Dummy
You need to connect all you component via a digital connection, either digital co-ax or optical.
Here are examples, and the best place to buy the cables:
Digital Co-ax, AKA SPIDF: http://www.monoprice.com/products/su...02&cp_id=10236
Optical, AKA toslink:
http://www.monoprice.com/products/su...02&cp_id=10229
The only way to get the best sound by hooking everything up to your TV is if your TV has digital audio inputs, and a digital output.
Your manual should detail the connections needed, so start with the manual.
Old 04-29-08, 09:17 AM   #3 (Link)
Zee
New Member
Alias: Zee
Loc: Coogee Beach, Australia
User: #19753
Since: Apr 2008
Zee is offline
mfk5331 - First of all, swap the speaker cables on your amp - front with rears. either that, or turn on the "speaker a" button. Having the center speaker and rears going means you probably have mixed the front and rears up. Perhaps (less likely but possible) you have a "speaker" button on the front panel of the amp that needs to be pressed.
eugovector wrote: View Post
I've noticed, from experience, that most TV's (possibly all? please correct me if I'm wrong) do not pass 5.1ch audio from the digital inputs to the digital out. Just an observation.
I'm not familiar with the model numbers of those Yammies, but the best idea is to hook everything up to the amp (provided it supports the switching of the highest level of video that you will use. ie - SVHS, component or HDMI) and hook up the audio using the appropriate digital connections.
eurgovectors link should give you an idea of what they look like.
OK - just had a quick look at the specs, seems it has 2 HDMI ins, 3 component ins, 2 coax in and an optical.
So, what are you trying to hook up to it?
From a quick browse of the specs, this unit doesn't upconvert to HDMI or component (again correct me if I'm wrong), if it does, your life will be far simpler.
Anyway, for now, hook the amp to the TV with a component lead. The Xbox to one of the component inputs, and either a coax or optical lead from the xbox to the appropriate input on the amp. You may need to read the manual to find out how to set the digital input you are using to work with the component input you are using.
I need to know what else you have to be able to help any further...
Z...
Old 04-29-08, 09:37 AM   #4 (Link)
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
tcarcio is online now
This may help.
http://www.howtohookitup.com/how_to_hook_it_up.html
Old 05-02-08, 01:18 AM   #5 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
superchad is offline
Hey mark, I sent you a PM if you want help....cheers
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
