System Setup and ConnectionDiscuss Newbie Needs help in the Home Theater | Audio | Video forum; Newbie Needs help Hello, I just bought a RCA model number RT2870. And I need some help with setting up the the speakers ... |
Views: 749 - Replies: 12
| | #2 | ||||
| Re: Newbie Needs help Hi Tyler. Start be reading the manual and following the instructions there. When you have specific questions, post them here and we'll be happy to help. Marshall Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 | ||||
| Re: Newbie Needs help Hi Tyler, Welcome to the Shack! When you say that you need help with the speaker setup to make it sound good are you saying placement? Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: Newbie Needs help does the receiver have some sort of tone or noise test tone for setting levels? Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #8 | ||||
| Re: Newbie Needs help Ok, in the menu of the receiver (on screen) there should be adjustments for each channel, use the test tone to set all the speakers to be at the same volume when sitting in the listening position. start with the fronts set at "0" (I assume that the level adjustments go from a "-10 to +10" or something like that). What are they set at now? How big is your room? Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #10 | ||||
| Re: Newbie Needs help Just for your info have a look at this thread as it will answer some of your questions. In your DVD player do you have the audio output settings set right? they need to be set to output Bitstream and make sure you dont have any setting like "night mode" or "dynamic compression" (DRC) turned on. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
