Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! RAM Electronics: Audio, Video, Home Theater and Computer Cables. PacParts: Replacement parts & accessories from the most recognized manufacturers in the Consumer Electronics Industry! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Fi Audio: Infinitely amazing balanced high end musicality designed drivers! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Elite Screens offers the finest in affordable projection screens. Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Go Back   Home Theater Forum - Home Theater Systems - HomeTheaterShack.com > Home Theater | Audio | Video > System Setup and Connection
RCA cabling type differences  Discuss RCA cabling type differences in the Home Theater | Audio | Video forum; RCA cabling type differences I'm in the process of setting up my system (Yamaha HTR-6080 receiver) and I have a question about cabling and ...
Views: 523 - Replies: 7
Old 04-23-09, 02:01 PM   #1
Alias: Harry Muscle
User: #9944
Since: Jul 2007
  Harry Muscle is offline
I'm in the process of setting up my system (Yamaha HTR-6080 receiver) and I have a question about cabling and connecting my subwoofer. My preference is to use Acoustic Research cables (decent price and good quality), however, the only subwoofer cables they make start at 15 feet. I only need a 6 foot cable at the most. So I was wondering if there would be any issues with using a composite video cable or a digital audio cable instead. Or are these cables someone different from the subwoofer cables? If someone could provide more details and a general explanation of how these cables differ, why, etc. that would be much appreciated.
Thanks,
Harry
Old 04-23-09, 02:19 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Re: RCA cabling type differences
For short distances any "rca" type cable will work. A component cable is simply three normal rca cables stuck together. I dont recommend using the cheep skinny a/v cables that generally come with most DVD players and TVs but the thicker ones will work just fine.
Home theater:
Onkyo TXSR805, Samson Servo 300 amp
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Panasonic BD60, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 04-23-09, 10:20 PM   #3
Shack Moderator
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
monoprice digital audio cable
Old 04-29-09, 03:34 PM   #4
Alias: greg
Loc: Saskatchewan Canada
User: #34503
Since: Feb 2009
  gobrigavitch is offline
I concur, for that short of a distance any RCA cable will work. RCA composite video cables are actually better then most audio cables due to extra shielding and thicker construction. If you have one of those lying around it would work splendidly
Posted via Mobile Device
Old 04-30-09, 10:25 PM   #5
Alias: Strype
Loc: NYC
User: #34121
Since: Feb 2009
  Strype is offline
for most of them the only "real" difference is marketing and price ...... when you start doing runs over 40' then you need to be a little more selective
Old 07-21-09, 01:21 AM   #6
Alias: Seth D.
Loc: Roeland Park, KS
User: #24168
Since: Aug 2008
  ndurantz is offline
Great thread. Answered my question, but raised another. I have an Acoustic Research composite video cable and a monoprice premium RCA cable available for sending the signal to my sub. Does it matter at all which one I use? It seems that the monoprice cable is thicker and therefore possibly better shielded?
Old 07-21-09, 05:04 AM   #7
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is online now
As has been said, most of the differences that matter for this kind of application are shielding and physical size and quality of build. For a sub, just about any cable with decent shielding will work with no significant difference in performance. for the length you are using, even the shielding is likely not an issue.
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 07-21-09, 09:41 PM   #8
Alias: Seth D.
User: #24168
Since: Aug 2008
  ndurantz is offline
Thank you! I appreciate the clarification.
« Home Theater Shack > Home Theater | Audio | Video > System Setup and Connection »
cabling, differences, type
Bookmark and Share
Dish Network
