Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Recommend DVI to HDMI or VGA connection
Discuss Recommend DVI to HDMI or VGA connection in the Home Theater | Audio and Video forum; Recommend DVI to HDMI or VGA connection Hello, I am new to the forum and have just finished our HT. I am connecting a HTPC to the ...
Views: 363 - Replies: 6
Old 08-07-09, 09:59 AM   #1
Alias: Mccrew
Loc: Newfoundland
User: #40391
Since: Aug 2009
  Mccrew is offline
Hello,
I am new to the forum and have just finished our HT. I am connecting a HTPC to the projector - I have DVI and VGA available on the video card. Which would you recommend - VGA to VGA on the projector or DVI to HDMI on the Projector? Distance ~ 25'.
Thanks!
Old 08-07-09, 10:52 AM   #2
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
Re: Recommend DVI to HDMI or VGA connection
While DVI to HDMI adapter cables are more expensive than VGA cables, I would think you would get a better signal from your DVI output which is compatible with HDMI through such an adapter cable.
Old 08-07-09, 12:48 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I agree with Jay, Going with the DVI to HDMI is the best choice as you will have far less problems with the dreaded HDCP handshake.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 11-05-09, 04:03 PM   #4
Alias: steiny93
User: #31709
Since: Jan 2009
  steiny93 is offline
agreed, dvi to hdmi, i have the same setup in our theater and it works great
you can find very reasonable cables online, monoprice / bluejeans / pacificcable all come to mind
Old 11-16-09, 02:08 PM   #5
Alias: Mccrew
Loc: Newfoundland
User: #40391
Since: Aug 2009
  Mccrew is offline
Thanks, consensus is to use the DVI to HDMI.
Old 11-16-09, 02:17 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Since your in Canada it will be cheaper to simply get it from here Unless you can get it locally for about the same. I have the exact same cable and its very good quality 33' long You will pay more after shipping for the cables from the US due to boarder fees.
Home theater:
Two Channel system:
My Webpage
Old 11-16-09, 02:54 PM   #7
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
You can also try Cable Sales Canada:
http://www.cablesalescanada.com/
We're all in this together!
Members DIY Subwoofer Database
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
connection, hdmi, recommend
