| System Setup and Connection Question about "Locking" Banana plugsDiscuss Question about "Locking" Banana plugs in the Home Theater | Audio and Video forum; Question about "Locking" Banana plugs Hi All. I hope this is the right place to post this question. I bought some "locking" banana plugs to ... |
Views: 254 - Replies: 4
| Question about "Locking" Banana plugs Hi All. I hope this is the right place to post this question. I bought some "locking" banana plugs to terminate my speaker cables, but they do not fit into any of the binding posts on either of my receivers (Denon and Onkyo) or to the back of any of my speakers (Paradigm). That leads me to wonder whether there are different specs for these plugs. I honestly thought the posts on all AV receivers and speakers are speced the same. Can someone explain to me why they do not fit? Thanks. | ||||
| | #2 | ||||
| Re: Question about "Locking" Banana plugs Denon and Onkyo are definitely standard. Do you have a link to the banana plugs you bought? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 | ||||
| Re: Question about "Locking" Banana plugs Make sure that they are not in the "locked" position when your trying to insert them into the binding posts. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | |||||
| Re: Question about "Locking" Banana plugs Quote:
![]() Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
