Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Setup Question - Integra 7.8 and B&W 5.1 Setup
Discuss Setup Question - Integra 7.8 and B&W 5.1 Setup in the Home Theater | Audio and Video forum; Setup Question - Integra 7.8 and B&W 5.1 Setup Hi All! I have an Integra 7.8 receiver with B&W CM7-CMCENTER-CM1 5.1 setup with Velodyne Mini-Vee subwoofer. I used the ...
Views: 245 - Replies: 2
Old 09-13-09, 03:56 PM   #1
Alias: mleuba
Loc: Maryland
User: #16981
Since: Feb 2008
  mleuba is offline
Hi All!
I used the Audyssey setup and then experimented with the setup menu, Speaker configuration, which allows you to select Full Band or a cross-over frequency for each speaker. I set my front CM7 to Full Band, the CM-Center and the CM-1 Rears I set to 80 khz(THX). To me, it sounds like this provides a clearer midrange, I think by directing <80 khz to the front towers and the sub-woofer only.
Does this make sense to you all, and have I "cancelled" the Audyssey setup by doing this or not...
Thanks!
Old 09-13-09, 04:31 PM   #2
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
Re: Setup Question - Integra 7.8 and B&W 5.1 Setup
mleuba, you have not cancelled Audyssey by doing this. In fact, the crossovers for the speakers are really the area that Audyssey rarely gets right, in my opinion.
Distance is nearly always very accurate for me. Level trim, a lot of the times is really good, too.
My suggestion is to play with the crossover settings for each set of speakers and see what sounds best that way. Go slowly through the crossovers and see which one provides the best sounding blend. Another thing you might want to do is check the frequency response with AVIA or something like it to see if one particular crossover setting gives you the smoothest response. This way you'll also be able to find out if one absolutely does not work and introduces any frequency nulls, too.
All in all, experiment, experiment, experiment!!! Hope this helps!
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 09-13-09, 05:33 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
An 80Hz crossover is the recommended setting by most people however as Jon says its all about what you think sounds best. If you want to "see" what your speakers sound like give REW a try as it will help you understand what each setting does.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
b&w, integra, question, setup
