Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Connections for the BFD / EP2500 combo...
Discuss Connections for the BFD / EP2500 combo... in the Home Theater | Audio and Video forum; Connections for the BFD / EP2500 combo... Couple of questions... I'm using the BFD and the EP 2500 I just want to know which cables should I ...
Views: 1824 - Replies: 18
Old 11-09-06, 09:05 AM   #1
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is offline
I'm using the BFD and the EP 2500 I just want to know which cables should I use between the two, XLR or 1/4?
Do I need to turn the clip limiter switch on?
I have a power center HTS5100, do you think I can hook the amp to the HTS5100?
Thanks!!
Old 11-09-06, 09:12 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Hook up BFD/EP2500..
Matters not. Either one.
Seems like a good idea.
Old 11-09-06, 10:39 AM   #3
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
On the power center, I'd think you'd need to make sure you are not overloading it. If there is room I'd use it.
You already connecting it?
Old 11-09-06, 12:36 PM   #4
Alias: Rodny
Loc: Millbrook AL
User: #158
Sonnie wrote: View Post
No!
Old 11-10-06, 06:41 PM   #5
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Normally I wouldn’t use a power center for an amp but the 5100 looks like it can handle it. Of course, that also depends on what all else you have plugged into it. One nice thing, you can plug the amp into the delayed outlet, and you won’t have that annoying BFD pop.
Old 02-24-07, 11:49 PM   #6
Alias: Rodny
Loc: Millbrook AL
User: #158
Exclamation Re: Hook up BFD/EP2500..
I read somewhere about changing the fan on the EP2500, I looked, but cant find it! the fan is to loud
Can some tell me were to find it !!!!
Thanks!!
Old 02-25-07, 12:41 AM   #7
Owner
  Sonnie is offline
Don't let it bite you ... the quieter fan thread!...
Old 02-25-07, 11:52 AM   #8
Alias: brucek
User: #6
  brucek is offline
I couldn't find any information that indicated explicitely that the EP2500 incorporates direct mounted output transistors, so the risk of a shock from a hot heatsink when the power is off appears minimal. I might discharge the heatsink though just to be safe if you're in there messing around with fans.
I also see where the silkscreen on the rear switches is in error compared to the manual and cartoon on the rear.
Note that it appears the cartoon is correct. Owners of the amp would know more about this than me, but I'm trying to give Sonnie a heads up anyway.
For example, note that the cartoon says that to turn OFF the low cut filter, the switch is to the right, but the silkscreen on the switch itself says the right is ON...... hmmmmm
Old 03-02-07, 10:46 AM   #9
Owner
  Sonnie is offline
I assume OFF is right for both LOW CUT FILTER INPUTS.
Old 03-02-07, 11:26 AM   #10
Alias: brucek
User: #6
  brucek is offline
I assume OFF is left for both LOW CUT FILTER INPUTS.
No, to shut the filters off, switch #3 and #8 are to the right............
Old 03-02-07, 11:37 AM   #11
Owner
  Sonnie is offline
Yeah... that's what I said...
Old 03-02-07, 10:29 PM   #12
Alias: Rodny
Loc: Millbrook AL
User: #158
brucek!!! so for the filter to be off the switch needs to be on!!?
Old 03-02-07, 10:43 PM   #13
Owner
  Sonnie is offline
Rodny.... ... don't you understand anything? In order for the filter to be on, the switch needs to be off.
Old 03-02-07, 10:51 PM   #14
Alias: Rodny
Loc: Millbrook AL
User: #158
Old 03-02-07, 11:12 PM   #15
Alias: brucek
User: #6
  brucek is offline
Well yeah.
I don't own the amp, I'm just pointing out an anomaly.
I would simply ignore the information on the rocker switch itself and follow the white cartoon. It would seem the cartoon is in the manual and on the amp itself.
So, if I wanted the Clip Limiter ON (control clipping), I would put the switches #1 and #10 to the right.
If I wanted the Low Cut Filter OFF (no low cut filter), I would put switches #3 and #8 to the right.
Old 12-25-07, 03:38 PM   #16
New Member
Alias: Danke
User: #14682
Since: Dec 2007
  danke is offline
I just received my EP2500. Is there a definitive answer to the Low Cut Filter switch position? I don't want a filter, right or left for the switch (facing the back)?
Thanks.
Old 12-28-07, 11:56 AM   #17
Alias: brucek
User: #6
  brucek is offline
Switch #3 = Right.............
Old 02-04-08, 02:50 PM   #18
Alias: Neil
User: #14216
Since: Dec 2007
  v1rtu0s1ty is offline
hi brucek,
What does LOW CUT FILTER OFF do, in layman's term please?
Thanks,
Neil
Old 02-04-08, 03:08 PM   #19
Alias: brucek
User: #6
  brucek is offline
The 30Hz and 50Hz LOW CUT filters are basically high pass filters that will remove frequencies below those specific settings.
When you shut them off, then the low frequency response will then become that of the amplifier itself, rather than being cutoff at 30hz or 50hz.
So, I suppose for the EP2500 it posts a low frequency response at -3dB down at 5Hz, you can say that with the cut switch off, you would enjoy a subsonic filter at 5Hz rather than the 30Hz or 50Hz with the cut filter set to on..
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
