Installed a new 58 Plasma on the wall. I am putting a plug up high on the wall to plug it in. Since I will no longer be able to plug it into the surge protector, can I just use a regular GFI plug to plug it into? Will this work as a surge protector? Is there a down side? Thanks!
I wanted the actual plug itself to be the surge protector without the need for anything else to be plugged in so I could save space since its behind a flat screen. I had the flat screen installed today and I have room so I ordered the panamax max2 which plugs into the outlet, but has its outlets on the sides which saves space. This should work well. Thanks for the tip....
Related Threads
742.3K posts
170.9K members
Since 2006
