I have my system hooked up, but am a bit confused about how to properly set up my HK AVR 635 receiver. I am not really sure what I am trying to accomplish in the first step of the "In/Out Setup" process called for in the owners manual. Am I supposed to select source for the purpose of telling the receiver which inputs I will be using? And am I supposed to make a selection for every choice listed? What exactly is the purpose of this?
My intention is to have the Blu-Ray do the processing and simply use the receiver for amplification and volume control. I have a Panasonic Blu-Ray player that has the latest Dolby TrueHD and DTS HD Master Audio capabilities and am sending the audio to the receiver analog via the 6 channel direct inputs.
Also, when using analog inputs to the receiver, is it correct to use the pre-out to the subwoofer? I have a Velodyne Impact 12. It doesn't seem to be doing much when I have everything going. I'm thinking I have it hooked up incorrectly or it needs to be adjusted during the receiver setup process.
Thanks for any help,
Boz
Boz
