why wont my wii play full screen its hooked up through my onkyo i played with all the options on the tv but did not change much 16x9 4.3 zoom modes nothing brought the picture out much is there a setting in the reciever. i have a lg lh90 thanks.
That should do it for you. you have to go into the Wii setup menu and change the output format there. I believe that might mean you need to have the component cables for hookup, but I'm not sure, it may still work with composite.
Are you using s-video or composite video? neither of these will allow you to use the 480p setting.
Related Threads
742.3K posts
170.9K members
Since 2006
