Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater - Audio / Video > System Setup and Connection
Donations Reviews Vendors
Views: 1247 - Replies: 5
Old 05-10-10, 04:55 PM   #1
New Member
Bronze Supporter
Sasquatch
Since: Dec 2009
  sassk is offline
I started this thread.
Projector, Reciever, Blue Ray compatability question
Hi,
I have a Pioneer VSX-1019AH-k Receiver, Mitsubishi HC3800 projector, and a Panasonic DMP-BD65 BlueRay player. When I connect the DVD player to the projector using HDMI, the picture is perfect. However, when I route it through the receiver (using new HDMI cables) the projector only shows snow. When I connect a low quality (composite input) video signal to the receiver, the projector works fine. I've tried 2 new HDMI cables and multiple HDMI inputs on the receiver always with the same results: great sound, nothing but snow from the projector. Any thoughts would be appreciated.
Thanks
Old 05-10-10, 06:21 PM   #2
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Since: Oct 2006
South of Adelaide
My Photo Gallery
  Prof. is offline
Re: Projector, Reciever, Blue Ray compatability question
Have you turned Kuro off on your receiver?..That causes incompatibility issues..and welcome to the Shack!
Prof..
Home Theatre...the never ending story!
www.dogboardingsa.com
Old 05-10-10, 07:06 PM   #3
New Member
Bronze Supporter
Sasquatch
Since: Dec 2009
  sassk is offline
Thanks - I did have it enabled. I've disabled it and unplugged the system. I'm still having the same problem. I'm thinking about giving up on HDMI and use component/audio connections. Any thoughts?
Thanks again!
Old 05-10-10, 09:25 PM   #4
Prof.'s Avatar
The Mad Professor
Since: Oct 2006
South of Adelaide
My Photo Gallery
  Prof. is offline
First thing to check is that you have your HDMI cable from the projector connected to the BD/DVD HDMI connection on the receiver..
If that's connected correctly, then there's probably an incorrect setting in the "Video Parameters".. Make sure that HDMI has been selected..
Prof..
Old 05-14-10, 08:42 PM   #5
New Member
Bronze Supporter
Sasquatch
Since: Dec 2009
  sassk is offline
Thanks for the tip. I have made some progress. I've tried a variety of settings and can get the configuration to work at 1080i. The dvd player direct to projector works at 1080p. According to the receiver manual, it should also support 1080p. I'll keep tweaking the dvd parameters to see if I can find the right combination to get to 1080p.
Thanks again for the tips!
Old 05-15-10, 06:17 PM   #6
Prof.'s Avatar
The Mad Professor
Since: Oct 2006
South of Adelaide
My Photo Gallery
  Prof. is offline
Glad to have helped..
Did you check the audio parameters for HDMI settings.?
It should be set to HDMI > Receiver..
Prof..
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater - Audio / Video > System Setup and Connection »
dmp-db65, hc3800, hdmi. compatability, mitsubishi, panasonic, pioneer, vsx-1019ah
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
