Beginner...I need help setting my system up! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Beginner...I need help setting my system up! in the Home Theater | Audio and Video forum; Beginner...I need help setting my system up! OK, so this is my first time using an HDTV and home theater system. I moved into a new home, ...
Old 02-05-07, 05:01 PM   #1 (Link)
New Member
Alias: Brian
Loc: weymouth, ma 02189
User: #6341
bpmccaff is offline
OK, so this is my first time using an HDTV and home theater system. I moved into a new home, and the cable guy came and set my video from tv to cable box and a dvd player and 5 speakers and subwoofer. The speakers come on when I am watching a dvd, but not when I am watching tv (the sound comes from tv speaker) The cable guy set the system up as follows: component cables from tv to cable box (audio and video), S video from tv to dvd player. Can someone please help me? I know I may need additional cables and.or completely re-wire the system. My DVD player/theater system and TV are all LG products, new models. The DVD and TV have optical slotsand HDMI slots.
Old 02-05-07, 08:57 PM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Beginner...I need help setting my system up!
bpmccaff wrote: View Post
If your TV and DVD player have HDMI why did he set it up with s-vid??? I would change this to HDMI connection.
I assume 'watch tv' uses the internal tuner in the tv. Look on the back of the TV for a pair of left and right audio outputs (RCAs) (it might be labelled 'monitor'). Connect these to a spare input on your receiver. I just noticed you r tv has an optical output, this is even better if you have a spare optical input on your receiver.
The sound will still play through your tv speakers, when you want to use the surround just mute the TV and select the input you connected the TV (on the receiver).
Harry.
Old 02-06-07, 07:30 AM   #3 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Hi Brian and welcome to the Shack,
Let me ask -- when you say "watch TV", do you mean you are then using the cable box? I think that's probably what you're doing.
This is kinda nitpicky, but I'd call that as going from the cable box to the TV -- the cable box is the "source" and the TV is the "target", if you will. So are there a total of five cables for this? Or three? Or something else? If there are three cables (red, white, yellow), I would suggest to connect your video differently. If there are five cables (red, blue green, red, white), then you're doing OK. If you are using S-video from cable box to TV, I think you can do better on video. Anyway, I think this cable box to TV connection is where you problem lies. Instead of sending audio from the cable box to the TV, we want to send it to your receiver. You said that the DV player and the TV have HDMI out/in, so I'm assuming that your cable box and receiver do NOT have HDMI. I'd bet your cable box and receiver both have optical out/in -- I would probably use that to connect audio from the cable box to the receiver.
I would remove whatever audio is going to the TV at this point. My TV has a way to say "don't use the speakers" somewhere in its menus. You may want to indicate to your TV that you are using all external audio. I think it just disables the amps and the on-screen display so that someone doesn't think they're turning it up, when in reality it will never get any louder.
So, I'd be interested to hear what you have going on there...
I also agree with Hakka that you should change the DVD to TV connection to HDMI (or at least component). I believe you will again get audio at the TV (when using a DVD w/ HDMI), but we can deal with that later. Your picture quality should improve quite a bit by getting away from S video).
-- Otto
Old 02-07-07, 03:11 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I think it will be a good idea to show pictures of the back of your TV, DVD, Cable Box, etc., so the experienced people here can suggest you how to connect the system ... if you can add pictures, you can give the brand name and models
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Setting up two subwoofers with BFD bittermelon BFD Forum 11 05-22-07 03:19 PM
Setting up SVS Sub Redman114 SVSound 10 02-24-07 04:51 PM
Setting BFD problem tdamocles REW Forum 13 10-07-06 12:34 PM
trouble setting up input Tonio REW Forum 6 06-20-06 05:22 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
