NewTV with only 1 scart socket
1K views 4 replies 4 participants last post by  BobGill
#1 ·
Hi
Just bought Sony Bravia tv with only 1 scart socket. I have 2 sources previously both connected by scart that I wish to connect. A DVD player and home cinema/surround sound ( a Sony compact av dav-S550). Neither have HDMI. DVD player has optical socket and scart. The surround sound has scart, optical digital in,and various video component sockets in/out. TV has component in and optical out sockets
Any advice would be appreciated
Many thanks
#5 ·
Hi there,
Sorry to jump on the post, but before I go out and purchase leads which turn out to be incorrect could you provide some additional info.
I have a similar set-up with an old Sony DAV-S550 and a new Sony Bravia (HX820), however I have a new Blueray player which is linked via HDMI.
I see that you have suggested component to connect the amp to tv, but the TV only has component IN and wouldn't I need component OUT? The Blueray actually has the component OUT and this works ok for disc, but is no use for the sky channels.
I was thinking of getting an optical cable to connect the amp to the TV, as I only need use of the surrond sound system, not the DVD component.
Cheers
