I have an old TV with only the coaxial cable outlet, which connects to a digital transport adapter. Another coaxial cable connects the adapter to a RF modifier (Philips SWS2100H/17). A DVD player (Magnavox MWD200GA) is also connected to the RF modifier through red, white, and yellow cables. Is there a way to connect a transmitter for wireless headphones to listen to the DVD's?
I would just split the red and white outputs of your dvd player, one will feed your tv and the other will feed your wireless headphone base unit. Youll need two of something like this....
Type A: Thank you. The connectors you recommend have one black and one red. Exactly which would I replace the respective white and red connectors that currently are in place?
Both the black and red outputs on the splitter I suggested are the same exact signal from whatever you plug the other end into, disregard the color difference. So you would buy two of the splitters and one each would go in the white and red outputs of your dvd player.
Related Threads
742.3K posts
170.9K members
Since 2006
