would this work?
work
745 views 1 reply 2 participants last post by  robbo266317
#1 ·
:foottap:hi if i was to connect a external rocksan k2 amp to a usa onkyo 5009 and connect a phono interconnect from the pre amp outputs of the onkyo 5009 to the input of the roksan k2 amp would it give me 11.1 channels instead of 9.2 and would the roksan amp have the connections to work between the onkyo 5009 and roksan k2 amp and also what would i have to change in setup options on the onkyo 5009 and roksan k2 amp to make it all work please need help asap please
#2 ·
The Onkyo manual states it is only 9.2 channels so it would be of no benefit.
Here are the possible configurations from their website:
DTS Neo:X™Adds Extra Dimensions to Surround
Sound
The TX-NR5009 is one of the first receivers in the world
to feature DTS Neo:X, a new technology that offers a
multitude of ways to set up the speakers in a 9.1-channel
home cinema system. A basic 5.1-channel set-up can be
complemented by one of three different arrangements:
(1) You can add surround back and front-height speakers to
bring out ambient, non-directional sounds; (2) You can add
surround back and front-wide speakers to provide a more
expansive soundstage; or (3) You can add front-height and
front-width speakers to create an immersive space without
needing to install rear speakers.
