Rocksan k2 stereo power amp question?
1K views 1 reply 2 participants last post by  wgmontgomery
#1 ·
Hi on the back of the rocksan k2 power amplifier it has two sets of rca inputs straight rca l+r and trimmed rca l+r i put the rca cable from pre-amp outputs onmy onkyo 5009 do i put the over end in straight rca l+r or in trimmed rca l+r to get 11.1 channels need help asap
#2 ·
I double checked my initial thoughts with the online user manual, and the only reason to use the trimmed input is if you need to adjust the input level from the preamp/SSP. If you use the straight input then you don't have to mess with the trim controls and is the recommended input for most applications. I hope that this helps; good luck!
